I think I might want a new head for my 325i sport. There's nothing wrong with the one I've got but it's just a bit worn and tired and a bit rattly so I was thinking if a new (secondhand) head was cheap enough, I could go through it all and recon everything so I can just swap it over when I'm ready ?
I fancy doing it this way cos the car is my daily driver so I don't want to rush things etc
325i sport head
ross_jsy
A sport head is no different to a normal head.
Put a wanted add up, should be able to pick one up for £150-250. I would suggest trying to buy a tested one as they have a tendency to crack.
Quaser
try adjusting the tappets if its rattly, makes such a difference!
otherwise, I have a good cam and rockers available if your cam is worn.
Chris_B86
Adjust the valve clearances, check the injectors, and check the manifold studs if you can hear tapping. As for paying £150-250 for a head, you're not far off getting a new engine with £250
That's about right. M20B25 bottom ends rarely fail, and it's not at all unusual to find a 200k+ mile one where everything is still within factory spec., so consequently they have little value.Chris_B86 wrote: As for paying £150-250 for a head, you're not far off getting a new engine with £250
I would guess that approximately one third of the B25 heads ever produced have cracked by now, so a good head is a valuable object and in demand.
Chris_B86
That's fair, my thought was why buy just a head when you can get a full engine, then maybe it could be a bit of a project, maybe build a 2.7 or 2.8 strokerBrianmoooore wrote:That's about right. M20B25 bottom ends rarely fail, and it's not at all unusual to find a 200k+ mile one where everything is still within factory spec., so consequently they have little value.Chris_B86 wrote: As for paying £150-250 for a head, you're not far off getting a new engine with £250
Grrrmachine
- E30 Zone Wiki / Team Member
Pretty much any head is going to be in worn condition if you buy it used. But if you can pick up a second one cheaply enough and rebuild it, then you can swap them over next time the cam belt needs doing.
Rebuild guide here:
http://www.e30zone.net/e30zonewiki/inde ... inder_Head
Don't think about any sort of porting or polishing though. There's a thread somewhere (engine swaps) with detailed explanations as to how advanced the 325i head was for its time, and how little you can improve it.
You may find though, as others have said, that you just need the tappets adjusting:
http://www.e30zone.net/e30zonewiki/inde ... M20_engine
Rebuild guide here:
Darren325is
Cheers everyone - some good advice there !
I got a PM from Maggspower last night who explained what he did and how much he could supply (outright or exchange) a recon'd head for. Has anyone had anything from or dealings with this bloke ?
maggspower
- Turbo Farmer Tractor Driver
Check the feedback section:
http://www.e30zone.net/modules.php?name ... ic&t=73547
http://www.e30zone.net/modules.php?name ... c&t=226109
Darren325is
That's me told then !
Will give you a call later this afternoon to discuss
maggspower
And another:
http://www.e30zone.net/modules.php?name ... maggspower
I've been on here almost 8 years now, and managed to keep my nose reasonably clean, and intend to keep it that way.
If you can't get through leave a message or text and I'll bell you back, my signal here is intermitent at best.
