Tech2 steering wheel
318isPMK
Post Sun Feb 24, 2013 11:42 pm
Hello,
I have two tech 2 steering wheels one is twisting around 11 - 1 o'clock as it would be in situe.
The other... the leather is grubby discoloured and tacky to hold.
Is there anything you can do without them having to be retrimmed?
I might offer the 2 of them to the retrimmer as credit towards one good one. the sad thing is the twisty one is in great nick leather wise.
Paul
mrLEE30
Post Mon Feb 25, 2013 7:23 am
from the rear of the steering wheel where the stitch is you can inject some rubber glue using a syringe, i have seen them do it here as Toyotas have the same habit.
Trick is to find a syringe with about a 1mm indder diamter and a glue that will flow through it.
syringe you should get from a good pharmasist, glue i can't help you.
Rtaylor2208
Post Mon Feb 25, 2013 11:47 am
Paul it might be worth selling both to fund buying one very good one. Even tatty tech 2 wheels seem to fetch decent money on eBay.
Chris_B86
Post Mon Feb 25, 2013 2:09 pm
Rtaylor2208 wrote:Paul it might be worth selling both to fund buying one very good one. Even tatty tech 2 wheels seem to fetch decent money on eBay.
+1 that, I'm still yet to see one go for much less than £100 regardless of condition
PG325
Post Mon Feb 25, 2013 9:01 pm
My Tech 1 370mm was twisting, it wasn't the leather, it was the inner rubber core.
Last week I bit the bullet and removed the stitching on the top half, cut into the rubber and glued it back down using Gorilla glue, I googled loose steering wheel and this glue came up time and time again as a suitable adhesive. I let it set for 24 hours and then stuck the leather back down with Evo-Stik impact and then stitched it all back together.
It's now perfect again with nice new black stitching!
