http://www.ebay.co.uk/itm/BMW-E34-S3-07 ... 4ac14c5f82
My search for the right ratio diff at a sensible price continues (see here http://www.e30zone.net/modules.php?name ... c&t=233850)
There are one or two other on ebay, but:
This one looks to have gone down with the titanic
http://www.ebay.co.uk/itm/E28-BMW-LSD-l ... 4ac140a8c8
And this one is £520!
http://www.ebay.co.uk/itm/E30-BMW-LSD-l ... 4ac1bc4d0d
Anyone got any other suggestions for getting the right ratio diff... Anywhere I can buy new internals for instance?
Is this a medium case E34 Diff?
I have an open medium case 3.07 that you could build a LSD into. I want £100 for it
greggers
Excuse my ignorance, but how do I make an LSD out of it...?
You swap a LSD centre into it , using the original case and crown wheel and pinion. Gareth on here is the man to contact re diff work / repairs.greggers wrote:Excuse my ignorance, but how do I make an LSD out of it...?
3.07 is rare in a medium case, they were only used on some 525 etas. The 3.07 LSDs in the above Ebay postings are big casing diffs from 535s and contrary to what the ads say , they will NOT fit an E30 without MAJOR mods. Their internals are not compatible with medium case diffs either.
The top ebay diff (bridgemotorworks) will not fit an E30 but the internals can be swapped into an E30 case by a specialist, Gareth would be my first choice
The second rusty f00ker (nice man from Barnet!) will never fit as its a large 210 diff
The rusty one won't fit, as Dan rightly says, but a couple of days in an electrolysis tank (with the breather just above the surface), would bring that up bright and shiny!
j2b
so the e28 3.25 lsd ive just bought even if i change the out put flanges to the drive shafts , wont fit the e30?
89 more door 6 pot
j2b
it has six , luckily enough ,i knew about changing the rear cover, i was under the impression all e28 diffs could be swapped over , now i know better.
.cheers
Sorry to clog up your post greggers, but you now know to look out for a 6 bolt bearing housing on a e28 diff, thanks to willnz
89 more door 6 pot
greggers
No probs.
@PacerPete, will you deliver that open diff you have?
