parts list prices please
Looking for genuine BMW parts at discounted prices? Try here!
BMW_E30vert
Post Thu Feb 21, 2013 11:48 pm
needed for my m52 conversion parts as follows:
E34 sump Gasket: 11131437237
Oil pickup gasket: 11411703947
Exhaust manifold gaskets: 11621744252
M50 intake manifold gaskets: 11611717259
M50 intake manifold profile gasket: 11611716174
E30 Brown temp sensor: 12621710512
E30 m20 flywheel bolts: 11221717840
E30 m20 flywheel shim (manual car): 11221262827
Clutch master connector: 21521154163
Rubber hose(part of clutch master assembly): 21521154164
M52 gearshift rod joint: 25111222688
M52 ZF Gearbox bolts: (various part numbers) don’t need dowel pin
M52 plate that goes between engine and gearbox (dust shield): 11141734019
regards Oz.
Cotswoldbmw
Post Fri Feb 22, 2013 1:48 pm
Hi There
E34 sump Gasket: 11131437237 £26.74
Oil pickup gasket: 11411703947 £3.16
Exhaust manifold gaskets: 11621744252 £11.26
M50 intake manifold gaskets: 11611717259 £4.82
M50 intake manifold profile gasket: 11611716174 £10.26
E30 Brown temp sensor: 12621710512 listed as NLA but they have 1 left £17.94
E30 m20 flywheel bolts: 11221717840 £2.53
E30 m20 flywheel shim (manual car): 11221262827 £20.29 German order 3-5 working days
Clutch master connector: 21521154163 £4.00
Rubber hose(part of clutch master assembly): 21521154164 £8.93 German order 3-5 working days
M52 gearshift rod joint: 25111222688 £10.45
M52 plate that goes between engine and gearbox (dust shield): 11141734019 £7.39
Prices inc. E30Zone Discount and VAT delivered to mainland UK
Please call our Parts Dept. on 01242 257999 and quote 23795
There is a P&P cost of £1.99 on all orders under £20
Please remember if you require an urgent response drop our
Parts Department an email
partscheltenham@cotswoldgroup.com
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
