DME relay check
xavier
Post Tue Feb 19, 2013 11:34 am
A while back on this forum I was told that I can bypas the DME relay by removing it and running some wire between two pins(17 and 39?). Are these pins on diagnostic plug? It is an 84 323i and I think the DCE relay is one of the 3 located on the passenger side of the engine bay up on the wheel well. I think the engine may be cutting out due to a dodgy DME. It seems to be worse on corners,which doesn't make sense to me.
Grrrmachine
E30 Zone Wiki / Team Member
Post Tue Feb 19, 2013 5:43 pm
xavier
Post Wed Feb 20, 2013 3:56 am
is it possible to use a multimeter instead of a test globe when checking connections? Is so do I take a current or voltage measure?
