BTB3 m50 idea
ross_jsy
Post Fri Feb 15, 2013 5:40 pm
Long story why, but I have a new BTB 3 manifold sat in my garage doing nothing. Just came up with an idea.
Does anyone know how different the flanges/exhaust port alignment is of an m50? My thinking was the primaries on the btb are designed for a 2.5, the m50 is a 2.5 so I imagine it could work very well. Basic thinking was chop off the m20 flange and weld on an m50 one, adjusting any difference in the spacing with some heat.
What are your thoughts?
BATTS91
Post Sat Feb 16, 2013 10:59 pm
I have often thought of this but using a cheaper stainless manifold to test . As shite as they are a hottuning one .
All this would surely be a better alternative if possible .
Does someone have both to marry up ??
BATTS91
Post Sat Feb 16, 2013 11:04 pm
Or someone with both sets of gaskets ?
ross_jsy
Post Sat Feb 16, 2013 11:53 pm
Just realised I think I have a spare set of m52 manifolds in the garage somewhere. I'll have a look tomorrow
ross_jsy
Post Mon Feb 18, 2013 10:57 pm
Had a look through the garage and I have misplaced my other set of manifolds.
So does anyone know what the differences are? Don't fancy taking the manifolds off for the 4th time
Post Mon Feb 18, 2013 11:04 pm
IMO the bends are too close to the head, due to the difference in engine angle and the width of the heads you will have to chop the primaries too much
ross_jsy
Post Mon Feb 18, 2013 11:09 pm
Good call Dan, hadn't thought about that. I'll have a look with that in mind tomorrow
BATTS91
Post Tue Feb 19, 2013 1:38 am
I hadnt thought about the engine angle either ! , still be interesting to continue researching .
