328 e36 what do i need off it?
dje30
Post Thu Feb 14, 2013 1:37 pm
ok so i have a 318i m40 and ive been offered my friends old 328 e36 drifter.
other than the engine, gearbox, ecu and steering rack
what else do i need?
i plan to use danthe exhaust mani's and looms
thanks
Jozi
Post Thu Feb 14, 2013 3:22 pm
You need the complete loom attached to the engine and also the manifold if your sending them to Dan. Could use the rad if it's still good and maybe the exhaust box/bits to make up a new system to fit the e30. Airbox and all bits attached to it also.
Post Thu Feb 14, 2013 7:46 pm
Key, ring antenna, receiver and EWS box plus associated loom and plugs.
BMW_E30vert
Post Thu Feb 14, 2013 8:17 pm
prop shaft as-well if you plan on using the zf box
