last few days there was a knock from the rear end, and just now its very pronounced,
its more or less under hard accelaration knock knock knock, getting faster with speed....
driveshafts?
i had a look when it first appeared there was some play but not much,
will they fall apart if left for a few months... as no monies at the mo
prop bearing was replaced and torqued down only a few months back, diff is also full of clean oil topped up only a few months back, all trailing arm bolts are tight,
also when i just braked i heard what sounded like a bolt clanging off and dropped on the road....
