hey,
im having a problem with my e30, all the indicators work apart from the n/s/f side indicator, there is no power going to it at all and i cant find out why, any ideas ??
side indicator problems
- **BANNED**
Is the harness plug attached to both the harness and the light?
It's difficult to get to the plug,you usually have to slide the bumper forward and grope up behind it to find the connector(I am assuming a plastic bumper version as you did not tell us!)
Then you need to check for power at the plug.
Welcome to the zone,BTW!
BenHar
Daimler man, I think you may be thinking about the wrong indicator. Side indicators are nowhere near the bumper.
Ben
Ben
- **BANNED**
Ben,the OP clearly states OSF!BenHar wrote:Daimler man, I think you may be thinking about the wrong indicator. Side indicators are nowhere near the bumper.
Ben
Of course,if you know far better than I,perhaps you would care to answer the question,rather than attempting to poke fun at those who are trying to help a new zoner.
Grrrmachine
- E30 Zone Wiki / Team Member
He clearly states NSF, not OSF, but I can see the confusion too. Either way, I thought both plugs (bumper indicator and wing indicator) share the same wiring to the hazard switch, and only split under the dashboard. I'd be checking there, and possibly for earth issues.
Grrrmachine
He clearly states NSF, not OSF, but I can see the confusion too. Either way, I thought both plugs (bumper indicator and wing indicator) share the same wiring to the hazard switch, and only split under the dashboard. I'd be checking the plug there, and possibly for earth issues.
- **BANNED**
Sorry!Grrrmachine wrote:He clearly states NSF, not OSF, but I can see the confusion too. Either way, I thought both plugs (bumper indicator and wing indicator) share the same wiring to the hazard switch, and only split under the dashboard. I'd be checking the plug there, and possibly for earth issues.
That was a genuine typo....
IF we are talking about the wing repeater,I would be starting by making sure that it's plugged in to the dashboard harness,but no doubt Ben has a completely different idea that I am longing to read!
BenHar
Daimlerman, sorry, too.
I read it as the near side repeater. Hopefully thye OP will be back to clarify.
Ben
Ben
alex_poulton
yes sorry i didnt say the wing indicator, i was tired when i posted
the near side WING indicator is not working, i tested for power at the end where the bulb goes and followed the wire back to the dashboard and its all connected but i didnt check for power there :/ ill do that today haha
thanks for the ideas though
gooner1
- Out humping Reindeer
War and Peace. The short version.
