325i trim
Jamboree
I've taken trim of my front and rear bumpers for spraying plus grills unfortunately I've broken quite a few fixing supports will they still hold with only a few left or should I be trying to find new ones
j2b
Get some new ones , your bmw dealers will probably will be able to get them .
89 more door 6 pot
Jamboree
Couldn't I just put a dash off super glue where the tabs are broken to hold it in place new trim is well expensive
ross_jsy
Well this is a council fest.
Yes of course you can bodge it with superglue, but why not do it properly for the sake of a few quid?
Jim320i
- E30 Zone News / COTM Team
Which parts have you broke exactly?
- **BANNED**
Reads like the OP has levered the trim bits off without first removing the bumper to squeese the tabs in to me...Jim320i wrote:Which parts have you broke exactly?
Kedge
Just buy good secondhand parts. Using superglue would be about the worst thing you could use to stick them back with as well.
Jim320i
Thats what I thought, if thats the case then has he damaged the rubber/plastic trim itself? If so, is it a pre or facelift car? And is it both front and back?daimlerman wrote:Reads like the OP has levered the trim bits off without first removing the bumper to squeese the tabs in to me...Jim320i wrote:Which parts have you broke exactly?
Jamboree
It's the plastic trim which you have to take of to remove the bumber the fasteners have been snapped ill just get the bloke to give them a scan if knackered hope he can get me a cheap set you boys think just a spot of glue to hold it is a bad idea I'm not going to drowned it in the stuff
Kedge
The little squares?? They are about 90p from BMW.
Super glue becomes brittle, you'd be better off using somekind of silicon sealer if you have to resort to sticking them in place.
Jim320i
What year is the car?
Jamboree
Daimlerman that's what I did levered of the trim with screwdriver I'm a novice carnt you tell
i thought you had to take that trim off to remove the front bumber 1988
Topblag
What you need is a haynes manual and a few days in the wiki section. You're not the first and won't be the last. You can pick up bumper trim on here if you look often enough.Jamboree wrote:Daimlerman that's what I did levered of the trim with screwdriver I'm a novice carnt you telli thought you had to take that trim off to remove the front bumber 1988
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Jamboree
Cheers for yours words of wisdom anyone spare a few grand so I can get it how I want it
