Front Panel real oem help
polsta
Post Tue Feb 05, 2013 1:00 am
Need a bit of help on this, ive been looking on real oem im a bit stummped, would appriciate some help
below are before and after pics, but i need to buy all new clips and fittings to replace the rusty ones, and im totaly stumped how to find them on real oem and exactly what i need
this was the front end
and this is it now
Post Tue Feb 05, 2013 9:40 am
Kedge
Post Tue Feb 05, 2013 10:19 am
Nice one Brian, I could do with getting some of those ordered. Think I'll have a look for some smaller packs though! 8)
Instagram - Kedge85
polsta
Post Tue Feb 05, 2013 10:26 am
thanks brian, is it mainly just those i need ? any idea what the common side there is ? ideally i dont want to be having to spend £30 on 300 of them
Jozi
Post Tue Feb 05, 2013 12:15 pm
I looked into this not so long ago also, I found the ones for the wings here: http://bmwfans.info/parts/catalog/E30/2 ... nel_front/
No 4, which is listed as 4.8 which is the size of those.
Only other reference I can find to them is here: http://bmwfans.info/parts/catalog/E30/2 ... _elements/
But you would need to measure the ones you have and see which on it is.
Wurth has them also in their catalogue (even listed as BMW specific).
Brian's like look like they will do though. Any idea how long they tend to last before they start rusting?
Kedge
Post Tue Feb 05, 2013 12:22 pm
Jozi wrote: Brian's like look like they will do though. Any idea how long they tend to last before they start rusting?
I would've thought they'd last at least few years of normal daily driving, but since none of ours cars are likely to see much severe weather as they'll mainly be weekend toys they should last a lot lot longer.
Instagram - Kedge85
polsta
Post Tue Feb 05, 2013 12:34 pm
thanks for that link jozi, the fittings one there looks lie could be some of them, the wing fittings ive already got
its just that front area, cant seem to find that actual bit on real oem, and all them holes under where the headlights sit, bits like that and them long plasticly chainsaw type clip things and bits and a break down of exactly whats there, its not as easy/clear to work out like other areas of the car
Jozi
Post Tue Feb 05, 2013 12:41 pm
I couldn't find any for the front panel either!
What I was planning on doing was taking of one of each size (could count them) and heading to a Wurth store and buying boxes of new clips and screws of the same size.
Kedge: It's hard to know I guess, they can always be replaced again in years to come.
polsta
Post Wed Feb 06, 2013 12:26 pm
ive ordered a couple of selections of the speed clips from ebay to start with, il see what bits are there that were removed and see if i can find them on real oem or something
