Sunroof delete
rhubarb
Anyone on here done a sunroof delete?
goosiegander
- Zonegoose
Yep, have a look at the first few pages of the x-works thread stickied at the top of the chat page,
Proper job!
Proper job!
rhubarb
Thanks mategoosiegander wrote:Yep, have a look at the first few pages of the x-works thread stickied at the top of the chat page,
Proper job!
Motorhole
Got one done here. Had a bit of Capri roof skin welded into the aperture. Skim and respray, can't tell from the outside.
rhubarb
Did you remove the cassette?Motorhole wrote:Got one done here. Had a bit of Capri roof skin welded into the aperture. Skim and respray, can't tell from the outside.
And no distortion? Dab with a damp rag job?
Andyboy
- Alpina Colada
The problem with that is that it will inevitably crack the filler around the sunroof aperture. If you MIG it continuously the skin will warp. A mate did this on an E36 and 2 years later it was cracking. You need to remove the cassette and also trim the return flange off.
Replacing the roof skin is more expensive but probably easier in the long run, and definitely a proper job.
Motorhole
Ah, that is something I havn't thought of. It's been ok so far but will see how it goes. I guess roof-flex results in the cracking? The car is caged too so I wonder if that reduces the amount the roof flexes.Andyboy wrote:The problem with that is that it will inevitably crack the filler around the sunroof aperture. If you MIG it continuously the skin will warp. A mate did this on an E36 and 2 years later it was cracking. You need to remove the cassette and also trim the return flange off.
G-Bear
There was a chap on here several months back that put a steel strip in around filling the gap between the aperture and sunroof panel, then welded it in. I think it was in the gallery section on a M3 touring build..
Kedge
If it's just for a track car just take out the cage and all the sunroof parts and then seal the sunroof panel in place or replace with something eve lighter. Weight reduced and no worries about cracking paint/filler. Pretty sure this is what DanThe has done.
If it's for a road car then you'll want to change the whole roof skin for a proper longlasting job.
rhubarb
This is my road car, it's a touring.
I'm getting a bit of water coming in at the long back edge of the panel, and it's dropping down onto the edge of the cassette.
I've cleared and hosed through all 4 drain channels/hoses.
OSF drain hole is starting to rust.
I never really use the sunroof, I find it causes a buffeting in the car when open.
The other simple idea I had was to buy and fit a wedge type seal that I can push in from above and put some rtv sealant all around before pushing the seal in.
I don't fancy chopping the roof off
I just want to keep the car in good nick and not have any damp problems
G-Bear
Here you go scroll about a third of the way down..G-Bear wrote:There was a chap on here several months back that put a steel strip in around filling the gap between the aperture and sunroof panel, then welded it in. I think it was in the gallery section on a M3 touring build..
http://www.e30zone.net/modules.php?name ... ht=touring
rhubarb
Thanks for thatG-Bear wrote:Here you go scroll about a third of the way down..G-Bear wrote:There was a chap on here several months back that put a steel strip in around filling the gap between the aperture and sunroof panel, then welded it in. I think it was in the gallery section on a M3 touring build..
