Are there any issues fitting the thermostat housing back on when using ITB's?
Rav's Chromie, Bodywork time
Bristol_Jer
Mmmm tasty!
- E30 Zone Meets/Events Team
That's the next headache to overcome
jimbom30cab
- Tech 1 freak
automotive porn
leeparkes
YesBristol_Jer wrote:Are there any issues fitting the thermostat housing back on when using ITB's?
Look proper Rav, good luck with the stat housing!
Cheers Lee
sag
Let me know rav how you get around fitting the housing. If you getting some one to modify it , I can send mine and get it done at the same time. As it will be something ill be doing in the future.
Andyboy
- Alpina Colada
Blimey, anchor management!Rav335uk wrote:Not much of an update, but cleaned up the inlet ports after getting the head back from Byron, and then test fitted the ITB's![]()
You like "Old Boy"
Is that bolts holding the trumpets on?
WTF are you looking at?DanThe wrote:Is that bolts holding the trumpets on?
Andyboy
- Alpina Colada
Rav335uk wrote:You like "Old Boy"
No, young ones.
Bought these over the weekend
Don't worry, there are 4 of them.
The_Diddler
- Love it up the more door !
/\/\ no likey
mcbonio
Polish them up nice, and they'll look good on a dark metallic coloured chromie e30.
They're 5 stud though.... ?
Seriously, when they look this good.The_Diddler wrote:/\/\ no likey
They'll be stripped down, and centres redone, with new dishes all round.mcbonio wrote:Polish them up nice, and they'll look good on a dark metallic coloured chromie e30.
They are 5 stud, but the ET is high enough so I can use some adaptors.
leeparkes
I thought the RS' were going on this?
shitzer rimz are horrid where's the split hartge's Ravvy ?
you using trumpets or the M5 inlet ?
Have the all still here lads.
RS's, Hartges, and the 17" and 18" split ACS wheels.
I'll keeping my options open, but the Hartges and RS's are defo staying for the car, and the 17" ACS ones.
I'm selling the 18" spilts.
Steve, similar set up, apart from the Plenium, mines from a M88 (M6) engine, so doesn't have the "Hump" in the middle.
The_Diddler
Epic councilnessRav335uk wrote:Seriously, when they look this good.The_Diddler wrote:/\/\ no likey![]()
Council at heart
Ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha ha
mikeyce30
who done your head matching to the itb adaptor plates? what throttles are you using?
basically i am looking for a simular setup
Throttles are M88, although S38 ones can be used too.
The work was done by "Maggspower" on here.
mikeyce30
approx cost of doing this?
Pm Maggspower.
It depends on how good the seats and valves are.
Small update.
Picked this up yesterday.
E30 handbrake handle covered in Alcantara.
Small update.
Well, time I suppose to pics of what was underneath the carpet.
Passenger side
Driver side
Glove box firewall
and finally driver side firewall
Most of the worst rust is on the firewall where water is coming through, one of the threadsbolts for the glovebox is completely gone, and on the driverside, ther's a hole which will need cutting out and welding in a new piece.
I'll get the rest of the mating up tomorrow and see what it's like under there.
The rest you can see isn't bad, but surface rust, so a lot better than I though, happy days.
Passenger side
Driver side
Glove box firewall
Crusty
scott180gtb
Can you weld Rav?
Cars
2007 VW Caravelle 2.5 TDI 250 bhp 550 NM
1989 325i Sport Gone
2003 E46 320d Touring
1998 E36 M3 EVO Track Toy
1996 E36 328i Sport welder-up project
Nope, it'll be like pigeon shit that will need grinding back to look "Good"
Jim320i
- E30 Zone News / COTM Team
Looks mint compared to what I just found under the touring carpets!
TPS
Is the Snickers Wrapper OEM?
That is caused by water in the scuttle box seeping down between the two bulkhead skins. You can patch the hole, but it'll still be festering from the inside.Rav335uk wrote: Most of the worst rust is on the firewall where water is coming through, one of the threadsbolts for the glovebox is completely gone,
The sealant in the bottom of the scuttle box needs renewing, but this is close to impossible without removing the top scuttle panel itself.
Is that removing the whole scuttle panel, if so, you can get new scuttles from the dealer?Brianmoooore wrote:That is caused by water in the scuttle box seeping down between the two bulkhead skins. You can patch the hole, but it'll still be festering from the inside.Rav335uk wrote: Most of the worst rust is on the firewall where water is coming through, one of the threadsbolts for the glovebox is completely gone,
Phil, I got hungry during the hard work
Jim, I was surprised too.
maggspower
- Turbo Farmer Tractor Driver
Like I always say, you dont need to be a good welder, you need to be a good grinderRav335uk wrote:Nope, it'll be like pigeon shit that will need grinding back to look "Good"
Contact: theengineshedonline@gmail.com
retroboyo
Awesome, but true. In brick laying we used to say you just need to be a good at renderingmaggspower wrote:Like I always say, you dont need to be a good welder, you need to be a good grinderRav335uk wrote:Nope, it'll be like pigeon shit that will need grinding back to look "Good"
