what do you think??
gnrsoul
Post Sat Feb 02, 2013 11:47 pm
318i m40
ok just want to double check and see what other people think?
have cream/mao on oil filer cap and in oil dip-stick tube? (but not in oil)
was thinking sh*t head gasket :cry:
so i have a block sniffer test at work so used it and all ok??
test ok, no vast amount of coolant loss, no water in oil
my guess is the rocker cover breather pipe is split but only at the end were i connects at rocker cover
and have also been told this can happen if you drive short distances/cold weather????
i only travel 2min down the road to work and same again at night (links with what i have been told)
if anyone else has any opinions on the subject please let me hear them
cheer
Post Sat Feb 02, 2013 11:57 pm
Sounds like condensation build up
gnrsoul
Post Sun Feb 03, 2013 12:23 am
cheers, i am waiting on new breather coming, so will put it on and see if this is were its getting in, but in the mean time will clean off and get the car out for a real good run to see if it clears it off
Post Sun Feb 03, 2013 12:25 am
If your running time is as states, it'll be back.
I've seen this on other cars too.
gnrsoul
Post Sun Feb 03, 2013 12:40 am
its pretty much a mile if that to my work but if i clears will just have to stop being a lazy git and walk to work
capnmchl
Post Sun Feb 03, 2013 9:14 am
I think this idea that mayo under the oil cap is HG failure needs to be eradicated and replaced by something called lazy mans syndrome.
Causes condensation build up, bore wash, lack of lubrication, and rotted out exhaust systems.
As above, take it for a good old cane on the motorway or a dual carraigeway, get it nice a hot. And then start walking to work.
