Wanted: ECU for 1991 325i - 0261 200 173 - SORTED thanks!
Nightshift
Post Fri Feb 01, 2013 9:49 pm
Been trying to get to the bottom of an engine cut out/idle issue. Had the ecu out and it turns out water has been getting into it (I guess that scuttle rust is worse than I thought).
As a result the corner of the circuit board is pretty corroded - time for a replacement. Anyone got a working one they are looking to shift?
