M20b25 cam belt tensioner
Idol
Does the above come with the spring? It doesn't show it online on car parts for less??
Rtaylor2208
Nope, you will need to get the spring from the steelers.
polsta
is this spring needed for a cambelt change or just if old one is worn/missing ?Rtaylor2208 wrote:Nope, you will need to get the spring from the steelers.
part number ?
Idol
Can't seem to find it on realoem, can anyone help me out and post the link?
bmw9818
Spring from Bm is less than a pound
Rtaylor2208
As mentioned below is a cheap part from the steelers and you might as well replace it while your changing the belt and tensioner form piece of mind.polsta wrote:is this spring needed for a cambelt change or just if old one is worn/missing ?Rtaylor2208 wrote:Nope, you will need to get the spring from the steelers.
part number ?
Kedge
Mine was missing even though the engine was meant to have had a recent cambelt
BenHar
http://www.realoem.com/bmw/showparts.do ... g=11&fg=25Idol wrote:Can't seem to find it on realoem, can anyone help me out and post the link?
number 18.
Ben
Kedge
55p on BM Miniparts.
Craggy73
The spring is only used to push the tension wheel onto the belt when replacing the belt, once it's in place you tighten the 2nd bolt in the sloted hole which locks the tension wheel in place. The spring is doing nothing then. I can only assume the spring is designed to apply the right amount of pressure on the belt.
Idol
Cool, thanks guys, yeah mine is missing, head has been off a couple of years and just started to refit it, can't seem to find it and would rather buy one than to guess the tension
Idol
Nice one, I looked at this diagram earlier and thought it must be here, but just couldn't see it, but I was looking on the iPhone! LolBenHar wrote:http://www.realoem.com/bmw/showparts.do ... g=11&fg=25Idol wrote:Can't seem to find it on realoem, can anyone help me out and post the link?
number 18.
Ben
Idol
Can't find it on there comes up not found!?Kedge wrote:55p on BM Miniparts.
Kedge
They aren't instock, special order so you have to request a price.Idol wrote:Can't find it on there comes up not found!?Kedge wrote:55p on BM Miniparts.
Idol
I'll go to the stealers then.
If the spring is missing, then pin 19 is probably missing as well.Idol wrote:Nice one, I looked at this diagram earlier and thought it must be here, but just couldn't see it, but I was looking on the iPhone! LolBenHar wrote:http://www.realoem.com/bmw/showparts.do ... g=11&fg=25Idol wrote:Can't seem to find it on realoem, can anyone help me out and post the link?
number 18.
Ben
The reason they go AWOL is that it's a pain changing the water pump with the fixed end of the spring pushing it out of line when you're trying to line the bolt holes up with their threads and keep the gasket in place.
Andyboy
- Alpina Colada
Long nose self locking grips ftw! If the spring is missing, you need to take it all apart to check for other craftsmanship.
AlpineCab
Second that - the "specialist" who did my head gasket swap obviously didn't tighten the head bolts up properly (or even at all).Andyboy wrote:Long nose self locking grips ftw! If the spring is missing, you need to take it all apart to check for other craftsmanship.
Oh, dear, I ask myself, why am I still losing water?
It's cos the f*****g head isn't bolted on!!!!!!!
And yeah, the spring was missing....
polsta
the spring is 0.68p , the dowel pin £3.01 , ordered both today
Idol
Yeah I ordered both too, as well as a new rear quarter for the resto
