Painting tech 2 kits
verde
Plastic primer oder regular primer? Wer getting very close now...
Not sure on what colour to use either but I shall contact autopaint and ask
Raise hell praise Dale.
- E30 Zone Meets/Events Team
You need "Plasticiser" for the paint to make it flexible.
Nato_e30
If its bare plastic (ie no paint on what so ever) use a plasticiser - standox make a good one and youl need one even coat, then a wet on wet primer (if your not planing on rubbing down between coats) if you plan on wet flatting the primer use a two pack primer, if you decide on the 'wet on wet' approach one even coat not to heavy ,check out the recoat time on the tin then go straight on with the desired top coat.
verde
It has paint on it. Its alpinaweiss, its been fitted before. Will I get away with flattening it, priming it then just painting, or plasticiser still needed?
Nato_e30
Ok its easy for best results then flast down with 1000g wet and dry then give it a go over with a grey scotch pad to get in all the gaps ect (your aim is to get rid of the shine and make it matt), aslong as you dont go through the paint you can put colour straight on. You only need to prime it if bare plastic or bere filler is visble
Primer is just a barrier to stop reaction and to make the paint adhere to the repaired area or bare plastic/filler or metal. If the panel is painted already its a piontless exercise priming it
Nato_e30
Note how just repairs are spot primed... this is ready for paint, I did a colour change on mine.
verde
Excellent thanks nato. I love that colour you chose, certainly one of a kind
Nato_e30
No probs
its going battleship grey now ;)
verde
Good god man, do you own a spray shop?Nato_e30 wrote:No probsits going battleship grey now ;)
polsta
you doing it yourself verde ?
this cars gonna be a ghetto superstar
just make sure you get the prep perfect, although my kit was nice enough ,when i saw it last week hed taken it right back got rid of all the silver and some spots etc on it, im guessing where hed filled in some deep chips and marks to get it smooth, its all in the prep
scott180gtb
This is a daft anal question but would masking up the gap from the sill to the floor and masking up the wheels etc effect the paint job?Nato_e30 wrote:
The reason for this is to stop over spray under the car.
Cars
2007 VW Caravelle 2.5 TDI 250 bhp 550 NM
1989 325i Sport Gone
2003 E46 320d Touring
1998 E36 M3 EVO Track Toy
1996 E36 328i Sport welder-up project
Nato_e30
No pal, I do that, when I do repairs I generally clean the crap of behind the wheel arch and behind the sill lip air blow it all aswell so no crap gets dislodged and bag the wheel up then I back mask it of the back of the sill and wheel arch. Stops that nasty over spray going under the car... if using a spray gun/compressor a bit of a tip I wet the floor under the car, not a massive puddle! The overspray sucks to the floor and it wont blow particals of the floor into the paint
verde
polsta wrote:you doing it yourself verde ?
this cars gonna be a ghetto superstar![]()
Iv been airbrushing for years, painted bmxes, odd bits and pieces round the house so fuck it, il try a car...have a go hero. I know its not going to be a great job but itl be better than what it was before. Heavily faded with no laquer on the roof bonnet or boot. As you say its all in the prep. Been taking our time making sure its all done proper
