205 50 15 tyres on standard rims
lisa325is
Post Tue Jan 29, 2013 10:07 pm
Just checking of anyone's got pic of 205 50 15 on standard e30 bbs rims..
Just not sure if these will look alrite or if there's much difference in the 55..
Thsnks
Post Tue Jan 29, 2013 10:12 pm
They look wrong even more so on a car thats not that low.
Post Tue Jan 29, 2013 10:13 pm
has to be 55's 50's don't fill the arch, :(
lisa325is
Post Tue Jan 29, 2013 10:16 pm
55s it is then..just don't wana spend moni on tyres then look crap!!
Gona stick ta finding 55s!!
Budgie325
Post Wed Jan 30, 2013 8:22 am
Shitter. I bought some 50's assuming it'd be negligable.
Going to try it anyway i think TBH. There's no decent options available in 55 (without spending £400!)
FinalD
Post Wed Jan 30, 2013 9:05 am
Brilliant little Java tool for this here: http://www.miata.net/garage/tirecalc.html
Your speedo will be out too never mind what it looks like.
Why would you compromise on the only contact patch you have with the road. Buy the correct tyres even if it costs £400!
Also, what?
http://camskill.co.uk/m53b0s289p0/Car_T ... _205_55R15
That'll be under £400 for 4 of the correct size and some decent brand tyres then, even after fitting!
Budgie325
Post Wed Jan 30, 2013 9:27 am
FinalD wrote:Brilliant little Java tool for this here: http://www.miata.net/garage/tirecalc.html
Also, what?
PMSL at that overreaction.
Contact patch with the road remains the same, both 205mm. Just the profile that differs.
The difference between 205/55/15's and 205/50/15's is looks. That's all.
Will try on my PE2's and see how they look.
FinalD
Post Wed Jan 30, 2013 9:31 am
The compromise was more aimed at people that buy the cheapest budget utter dross rather than changing the size by 3.4%. :P
Well it isn't just size now is it? ;)
Granted it is only 2mph out at 60 (and speedo will over read) but as the speedo will likely be out anyway, sensible to stick with the correct size. :D
Budgie325
Post Wed Jan 30, 2013 9:34 am
No, it's still only size that differs.
No safety implications like you suggested.
I'd be amazed if all speedos were bang on after 20 years anyway, so not in the slightest bit worried about that.
Just out of interest, if you bought a newer BMW, a 1 series for instance, would you re-fit runflats when they came to need replacing?
FinalD
Post Wed Jan 30, 2013 9:40 am
The safety is about buying £20 linglongs vs £80 Contis, rather than the size of the tyre. :P
I just wanted to make sure that you do buy/have got decent rubber, but you do anyway so that's beside the point. :)
3.4% difference isn't actually too bad really, I'd still personally only go with the manufacturer specified size though.
I'd never fit runflats, they make the ride crashy and you can put much better rubber on if you go for normal tyres in the correct size. :)
faze30
Post Wed Jan 30, 2013 9:50 am
stick to 205/55/15,
maybe if your car was lowwered then 205/50 may look good.
IlovM42
Post Wed Jan 30, 2013 9:51 am
i'm on 205/55 R15 on my 318is, don't know how much it's lowered but looked great for me :)
verde
Post Wed Jan 30, 2013 10:07 am
IlovM42 wrote:i'm on 205/55 R15 on my 318is, don't know how much it's lowered but looked great for me :)
Got some pics?
Raise hell praise Dale.
IlovM42
Post Wed Jan 30, 2013 10:22 am
I'm also buying 205/55 r15 tire at the moment but it's not for the look, just the need to have the correct tire size here in france :x
Rtaylor2208
Post Wed Jan 30, 2013 10:56 am
Running 205 50 15s on mine as per the pitcure below. Lowered -40mm and have no issues with, ride, grip or arch gap.
polsta
Post Wed Jan 30, 2013 12:32 pm
my old is was 205 55 15 with eibach , and looked perfect
aze30
Post Wed Jan 30, 2013 10:08 pm
FinalD wrote:The compromise was more aimed at people that buy the cheapest budget utter dross rather than changing the size by 3.4%. :P
its a good thing as it will keep you on the safe side at speed cameras lmao :D
Post Thu Jan 31, 2013 12:42 am
they look fine, but not on standard suspension ride height
faze30
Post Thu Jan 31, 2013 9:38 am
the profile is the percentage of the width.
205/50/15
50% of 205 on a 15" rim.
polsta
Post Thu Jan 31, 2013 12:40 pm
thanks for the pm reply faze, but them prices were some what steep 8O
Sjoerd320i
Post Thu Jan 31, 2013 1:43 pm
This is on 205/50/15
