As per link,
'87 Sport in lachs with good options + aircon but its had a hard life!
Its a hound for sure but like all things has potential,
Discuss...
Bab will be printing that out and pinning it up beside his Tech I Sport. I believe his rust is similarly unmodified.spook wrote:That will be worth ten grand in a couple of years if you tart it up.
It's ok, looking at the second pic, it does have one fitted already, he doesn't need to worry about where to drill.spook wrote:Does it have a hole for the Ariel?
I can supply a chip for the 073 ECU, as fitted to Tech 1 Sports, and early pre-facelift 325i's.Simon13 wrote:you can't chip these early cars iirc?
I'll grab a scope from work and have a look before wasting an hour stripping off the head Pete,pacerpete wrote:It's an illness !I have a good hi comp bottom end if its ugly in there. Personally, if the cam looks OK and there is no carnage in the cylinder, I would be knocking back the shaft and sticking a rocker on it in situ
snakebrain wrote:Bab will be printing that out and pinning it up beside his Tech I Sport. I believe his rust is similarly unmodified.spook wrote:That will be worth ten grand in a couple of years if you tart it up.
There's a lovely car inside that somewhere..
Is there carnage ? I assume there is or else you would be just replacing the one foooked rocker in situ. .goosiegander wrote:Started stripping down the timing covers and cooling system today,
Aircon condenser is past its best so that can go, luckily i have a load of spare aircon gear to go on without too much hassle at some point in the future.
Set head to tdc, hopefully strip everything else down tomorrow,
Noticed that there is no power assistance fro the rack, debating to spec up while i'm there as i have spare PAS gear sitting idle...
Picture tomorrow hopefully
Sounds like it could well have suffered the same fate as my engine then, mashed piston(s).bss325i wrote:Valve to piston contact due to failed belt tensioner if i read that right on the 5 forum?
Whats the plans Chris? Full on resto or patch up and use?
Its been a while since i've done a head on an m20 and the bolts have never been changed, didn't feel as much compression as i'd expect cranking it over so its worth doing the stem seals and checking the guides at the same time, cant smell and fuel in the oil nor is there mayo...pacerpete wrote:Is there carnage ? I assume there is or else you would be just replacing the one foooked rocker in situ. .goosiegander wrote:Started stripping down the timing covers and cooling system today,
Indeed, Tech 1 lines appeal to me far more now than when i joined the zone...lyricalnut02 wrote:tech 1s ftw!!! quiet a few popping up on the zone now good to see
