Midlands Touring Slaaaag - Wust Wepairs
Jim320i
E30 Zone News / COTM Team
Post Mon Jan 28, 2013 12:24 pm
New car, new thread.
Bought the car from Meatballs82, who bought the car from Kedge. Both of which looked after it well :mad:
Drove it home last night, everything doesnt work very well.
Thought I would make an early start on it today. Switched the wheels. Sorted the squealing belts and then the driver decided to not open anymore...
Last 2 hours trying to fix that and still no better off. Removed the actual barrel and that looks like its popped off its spring so took a barrel from a breaker, and changed the lock mech part as that didnt seem to be catching... Now it doesnt open back up.
In a proper mood with it so ive come in for half and hour to warm up as its fooking freezing outside. Gonna remove everything from another breaker and rebuild the complete lot into the touring door and that should hopefully sort the issue as I cant seem to narrow it down to anything.
Anyway, pictures of the bbs fitted and those 16" removed :cool:
Old
New
bigwinn
Post Mon Jan 28, 2013 12:26 pm
looking good
is it malachite?
Bronzit gone- she lives on
'89 325i auto touring: Malachite Green
Now, I'm no gynecologist, but I know a tw4t when I see one...
Post Mon Jan 28, 2013 12:31 pm
countdown to fragfest has commenced !
i'd take the door off and take it inside to fix the lock :D
Kedge
Post Mon Jan 28, 2013 12:37 pm
Jim320i wrote: Last 2 hours trying to fix that and still no better off. Removed the actual barrel and that looks like its popped off its spring so took a barrel from a breaker, and changed the lock mech part as that didnt seem to be catching... Now it doesnt open back up.
In a proper mood with it so ive come in for half and hour to warm up as its ********* freezing outside. Gonna remove everything from another breaker and rebuild the complete lot into the touring door and that should hopefully sort the issue as I cant seem to narrow it down to anything.
Just showing how much it likes its new owner I guess! :wink:
Instagram - Kedge85
Meatballs82
Post Mon Jan 28, 2013 12:41 pm
Looks loads better on the BBS, can't believe you broke the door lock already! was fine yesterday :D
Were you surprised at the weight of those 5 spokes when they came off? I was! :mad:
Kedge
Post Mon Jan 28, 2013 12:42 pm
Meatballs82 wrote: Were you surprised at the weight of those 5 spokes when they came off? I was! :mad:
They're foooooking heavy!
Instagram - Kedge85
Meatballs82
Post Mon Jan 28, 2013 12:48 pm
Jim320i wrote:Both of which looked after it well :mad:
Cheeky coont - I serviced it (everything except plugs, Dave changed them before I bought it) cambelt, water pump + antifreeze changed, drive belts changed, tracking sorted, Beast of a new battery and I even pumped the tyres up once!
Did you even spend that much on your chromie?!?!?! winkeye
Jim320i
Post Mon Jan 28, 2013 12:49 pm
I'm suprised on how easy the BBS fitted straight on... Fook knows what you was playing at when you tried to put your Alpina Reps on it Matt :mad:
@Mick - I think I'm going to do that, just need to warm up a bit first. Although a bit worried its gonna pish it down shortly.
Got a Tech 1 gear knob, steering wheel and leather handbrake gaitor and grip to add to it later too, just to spec it up a bit. :D
Hoping the cream leathers out of the 323i is the same shade as whats in it so I can swap that driver seat over too so :cool:
Jim320i
Post Mon Jan 28, 2013 12:50 pm
Oi, dont speak my about my chromie in that tone :evil: :D
Kedge
Post Mon Jan 28, 2013 12:53 pm
Jim320i wrote:I'm suprised on how easy the BBS fitted straight on... Fook knows what you was playing at when you tried to put your Alpina Reps on it Matt :mad:
:rolling:
Jim320i wrote:Got a Tech 1 gear knob, steering wheel and leather handbrake gaitor and grip to add to it later too, just to spec it up a bit. :D
Should be a tech 2 wheel fitted if you want proper OEMness, leather handbrake handle is correct, dunno what could have possibly happened to them! :teehee:
Instagram - Kedge85
Meatballs82
Post Mon Jan 28, 2013 12:56 pm
Forgot to mention - This heaps Jackin pads have been deleted :bolt:
Kedge
Post Mon Jan 28, 2013 12:57 pm
Maybe on cleaning products! :wink:
Jims idea of maintenance is if it don't work frag it!
She served us well dude! :cool: Was barely running when I picked it up.
Instagram - Kedge85
Kedge
Post Mon Jan 28, 2013 12:58 pm
Meatballs82 wrote:Forgot to mention - This heaps Jackin pads have been deleted :bolt:
Deleted in style :eek:
Instagram - Kedge85
Post Mon Jan 28, 2013 12:59 pm
Lying fooker, you told me you put Dishwasher water in the coolant side of it, and Old engine oil one of your punters gave you 8O
Jim320i
Post Mon Jan 28, 2013 1:03 pm
Also has the sill jacking points deleted too :mad:
Was fun using the factory jack and hoping it didnt slip. Couldnt be bothered to find the trolley jack out.
Kedge
Post Mon Jan 28, 2013 1:07 pm
It does have some interesting welding action, that's why I bought the skirts off Indy to hide what it all, don't poke the bottom of the passenger wing too hard, the tigerseal didn't have much to cling to. :mad:
Instagram - Kedge85
Jim320i
Post Mon Jan 28, 2013 1:10 pm
Aha... I wouldnt poke it, if it was there to poke... 8O
Fooker rotted away and now there is no base to the wing and no se skirt to cover the hole up :mad:
Need to steal a wing from the Sport but fook doing that today.
Headlights are gonna be switched too, driving home last night with the lights on. Pointless
Speedo needs fixing too :cry:
Kedge
Post Mon Jan 28, 2013 1:17 pm
:chuckle: Doesn't surprise me that it ended up falling off!
Didn't Matt put some fancy ultra bright bulbs in?
Instagram - Kedge85
Meatballs82
Post Mon Jan 28, 2013 1:20 pm
Kedge wrote::chuckle: Doesn't surpise me that it ended up falling off!
Got a osram nightbreaker in the drivers side, broke the passengeer side one so just put the original bulb back in :D
Jim320i
Post Mon Jan 28, 2013 1:21 pm
He must have fitted them just to the high beams and normal lights are awful :( I have some other smilies I can switch them with though.
Was debating about grip filling the tech 2 kit to it but dont have the skirts for a 4 door :(
Kedge
Post Mon Jan 28, 2013 1:23 pm
Fook that, get the kit sold!
Might not help that the headlights aren't a matching pair, one smillie and one bullseye!
Instagram - Kedge85
Duke137
Post Mon Jan 28, 2013 2:21 pm
There is no way this thread will last, I bet it will be fragged within 2 months! :)
Jim320i
Post Mon Jan 28, 2013 3:15 pm
Wont be fragged Ferg, I have way too much scrap at the moment to keep me going for a very long time.
I am however very short tempered at the moment, trying to sort this door :cry: Switched everything over and straight the way, it just locks into a position, and now wont shut, just opens back up with no catch :(
Gale force winds outside too and im fooking freezing. If anyone has a Touring door that works in Diamond Schwarz local to me, let me know... I'd rather just change the door at this rate :mad:
bmandy68
Post Mon Jan 28, 2013 3:57 pm
Nice little run about mate looks loads better with the bbs wheels
blackE30indy
Post Mon Jan 28, 2013 4:40 pm
Jim,I've got a spare touring drivers door in diamond black if you want it,no use to
Me,and it comes with a lock and a key if I can find it :D
blackE30indy
Post Mon Jan 28, 2013 4:46 pm
Found the key,and the lock seems to be working :D
Jim320i
Post Mon Jan 28, 2013 4:53 pm
Indy, got it sorted now mate :D Didnt put the barrel lach into the fork on the inner mech part :cry:
Need to fit the window properly now though but I'll sort that tomorrow
Took it for a spin too to check the belt sqeualing and the wheel wobble, both now fixed :cool:
Its bloody quick :D Need to sort the speedo out and sort the loose gear knob and change a couple of bits but its good to roll.
Insured it the other day too, £134 for the year on a classic policy winkeye
blackE30indy
Post Mon Jan 28, 2013 4:55 pm
Haha,no worries mate,atleast you've got a e30 that you can actually use now :D
Jim320i
Post Mon Jan 28, 2013 4:57 pm
Thats it dude. Been without one for ages, feels good to drive one again :D
blackE30indy
Post Mon Jan 28, 2013 4:58 pm
you'll be crying soon,complaining of fuel usage :D
Kedge
Post Mon Jan 28, 2013 4:59 pm
Who you insured it with? 8O
Instagram - Kedge85
Jim320i
Post Mon Jan 28, 2013 5:09 pm
Through Lancaster mate, one of the sub companies that comes up. KGM or something like that.
The week before I tried to do the same quote and it was over £600... :mad:
I sat and tweeked the quote too so its only low millege, 3000 a year with a value of... £4000 :mad: Thats the highest it went to without going more expensive so thought I would would put. Obviously I know its not worth that much, but if I put £1000 for example they would try and give me £200... Hopefully if something happened they'd give me £1500... :D
Or, ideally, I dont bump it!
zaust
Zone day release
Post Mon Jan 28, 2013 5:18 pm
My touring I known as the slag. Don't go there lol.
M30 Tech 1 Touring on gas.
Bump
Post Mon Jan 28, 2013 6:54 pm
Why have you got the UK's biggest pedophile as your avatar?
You don't win friends with salad.
Cloggy Saint
Post Mon Jan 28, 2013 7:09 pm
Bump wrote:Why have you got the UK's biggest pedophile as your avatar?
For some reason there's a large amount of zone members who are obsessed with paedophiles/paedophilia.
