Removing m30 fuel rail
mcbonio
Post Thu Jan 24, 2013 8:29 pm
I want to test for a leaking injector, can the fuel rail be removed without taking the intake fannymold off like on an m20?
leeparkes
Post Thu Jan 24, 2013 11:32 pm
Yes, there's enough room to get the injectors out by popping it upwards, bit fiddly but can be done.
Post Fri Jan 25, 2013 8:41 am
Bast4rd job to do with the manifold on though.
Bristol_Jer
Post Fri Jan 25, 2013 6:58 pm
Also make sure the area around the injectors is nice and clean so no crap falls into the manifold when you pull the injectors out
walinsky
Post Fri Jan 25, 2013 8:36 pm
Bristol_Jer wrote:Also make sure the area around the injectors is nice and clean so no crap falls into the manifold when you pull the injectors out
+1
mcbonio
Post Fri Jan 25, 2013 8:50 pm
I'll have a go in the morning, just want to pull them out to see if one is dribbling...
Bristol_Jer
Post Fri Jan 25, 2013 9:16 pm
If you've got the cash spare send them off to Injectortune to be reconditioned, they were advertising on here a while back, thats where I sent mine to, you get them back in a few days, great service :)
mcbonio
Post Fri Jan 25, 2013 9:27 pm
Yeah already got his details at hand.! Cheers Jer.!
leeparkes
Post Fri Jan 25, 2013 11:05 pm
Jims gone for some 4 pintle jobbies from the states.
http://www.e30zone.net/modules.php?name ... =injectors
mcbonio
Post Fri Jan 25, 2013 11:40 pm
Yeah they look good, but they are 19lb/hr .. m30 ones are 17lb/hr. So I'm not sure how they will perform on a standard engine... really not sure I want my m30 using more fuel than it does now.. good price though.!
I might just go down the refurb route with injectortune, thats if I do infact have a leaky injector.
leeparkes
Post Sat Jan 26, 2013 12:09 am
You sure there 17lb/hr, i always had it my head there 19lb?
jimbom30cab
Tech 1 freak
Post Sat Jan 26, 2013 7:14 am
Yer I have those 19lb jobbies but I have not run the engine yet. I have loads of spare m30 535 standard injectors if anyone needs any, postage cost only
mcbonio
Post Sun Jan 27, 2013 1:58 pm
Ok so pulled the injectors out today, they look like this;
See the one on the end, the little yellow cap on the end is missing half.! Could this be the cause of my problems?
I also checked for dribbling, they didn't so perhaps one might be slightly blocked?
Post Sun Jan 27, 2013 2:03 pm
They look Fooked! 8O
mcbonio
Post Sun Jan 27, 2013 2:12 pm
Always appreciated your concise diagnoses Rav.. :)
Post Sun Jan 27, 2013 2:19 pm
leeparkes
Post Sun Jan 27, 2013 10:51 pm
Yep Ravs right, there fooked. 8O
jimbom30cab
Tech 1 freak
Post Sun Jan 27, 2013 10:52 pm
I put 3 in with the alternator, did you want another 3 also ?
mcbonio
Post Wed Jan 30, 2013 11:26 pm
I should get my refurbs back tomorrow, I'll bang em in and see if it helps.
I fitted the alternator tonight with, thanks for polishing it up too.! Will let you know if it works tomorrow.
pianist
Post Thu Jan 31, 2013 12:00 am
leeparkes wrote:You sure there 17lb/hr, i always had it my head there 19lb?
I think yelow/orange ish injectors are 19lb
mcbonio
Post Thu Jan 31, 2013 12:55 am
Yeah the ones I have a 19 lb from m30 3.0, 3.5 and m40 1.8 engines.
Bristol_Jer
Post Thu Jan 31, 2013 6:23 pm
mcbonio wrote:Yeah the ones I have a 19 lb from m30 3.0, 3.5 and m40 1.8 engines.
M42 I thought, iS engine?
mcbonio
Post Thu Jan 31, 2013 9:45 pm
Yes you're right Jer. I mean m42.!
I fitted the refurbed injectors today, the engine is so much smoother.! Well worth doing.
jimbom30cab
Tech 1 freak
Post Thu Jan 31, 2013 9:46 pm
That's great, hope the alternator helps also.
mcbonio
Post Thu Jan 31, 2013 10:03 pm
I fitted the alternator yesterday and tested it today. Works great and cured my problems. ABS light is off now, no more dim lights and almost stalling when I put the clutch in. FULL POWER.!
Thanks Jim.!
Bristol_Jer
Post Thu Jan 31, 2013 10:16 pm
Nice work, is it running 100% now with no problems? :)
mcbonio
Post Thu Jan 31, 2013 10:27 pm
Yeah, very very perky. Hadn't realized how bad the car was with the old alternator. My tach, econo and temp gauges have started wandering around again though.! Bah need to sort that it's so annoying.
Bristol_Jer
Post Fri Feb 01, 2013 8:44 pm
From what I've read on here there is a brass nut on the back of the clocks that comes loose. My temp gauge goes wonky when over 1/4, but not got round to sorting it yet
mcbonio
Post Fri Feb 01, 2013 8:53 pm
I fixed it.! I disconnected the battery and joined the 2 cables together, turned the ignition to position 2 and left it for 10 mins. Connected it all up again and now they work.
I did this as I was reading a procedure to reseting the ECU capacitors that remember the adaptive values even when the battery is disconnected. I had changed so many parts on the engine over the last few months and it just wasn't running right. It's brilliant now, more power and smoother. Seems to have cured that lumpy cold idle I had too. Everyone needs to try this.!
http://twrite.org/shogunnew/fixes/contr ... _Procedure
jimbom30cab
Tech 1 freak
Post Fri Feb 01, 2013 9:39 pm
well done mate, check you out hey !!!!!, nice one, glad it's all working well :)
leeparkes
Post Fri Feb 01, 2013 9:50 pm
Its nice when they wake up isnt it. :cool:
mcbonio
Post Fri Feb 01, 2013 9:58 pm
It is! I think I've changed so many parts and done so much, the ecu settings were adjusted to compensate for bad parts. Then continued to run not great even with the new parts if you get me. New parts running on settings from poor parts.
Interesting how disconnecting the battery doesn't really reset the ecu. You then have to short the entire electrical system to make it forget everything.
jimbom30cab
Tech 1 freak
Post Fri Feb 01, 2013 10:03 pm
i'll do that when the lump is in, good tip. Problem is i keep working on the tech 1 and have neglected the M30 now for a while, need to get started on it again. So close now to finishing it also, I just need the motivation to carry on.
mcbonio
Post Fri Feb 01, 2013 10:48 pm
We'll all come over to yours and cheer you on.!
