Trolley Jack or Bottle Jack
redrobbie
Post Sun Dec 25, 2005 3:18 pm
Put simply what should I go for a trolley jack or bottle jack?
And what tonne should I go for?
Thanks. :D
Happy Christmas
smithy318i
Post Sun Dec 25, 2005 3:42 pm
2 tonne trolley jack from halfrauds does the job for me.
bottle jacks are more dangerous i think. (unstable on unlevel ground)
hammoj28
Post Sun Dec 25, 2005 3:58 pm
Yup a 2tonne trolley jack is what I use. They aren't that expensive either. Those halfords ones are quite good. Think they do a deal with stands? Also get a set of axle stands for extra safety plus they come in very handy! Dont really trust bottle jacks that much.
24v tech2
Post Sun Dec 25, 2005 4:20 pm
Post Sun Dec 25, 2005 4:40 pm
cheap trolley jacks often don't go low enough, and almost always don't go high enough. Was given one a few weeks ago that won't even lift an E30 high enough to remove a wheel.
Worth spending a little bit more for a half decent one.
redrobbie
Post Sun Dec 25, 2005 8:09 pm
thanks for the link :D
Do you think this one is worth it?
CTJ2000G, and get the stands from halfords, save a fiver! winkeye
I checked the halfords jack and it doesn't go up as far as the machine marts. What do you think guys.
charlE30
Post Mon Dec 26, 2005 3:52 pm
I bought the CTJ3000G - 3 Tonne Professional Garage Jack from machinemart and some extra large axle stands (AS10 Axle Stands), well happy with it highly recommended. It's nice to be able to get your car high enough to crawl around under. The axle stands from Halfords don't go high enough with decent trolley jacks.
It makes under the car jobs much easier :thumb:
BMW F31 335d xdrive
redrobbie
Post Mon Dec 26, 2005 3:59 pm
Great :D. Thanks guys for your help.
Thanks for the heads up on the halfords axel stands charlE30, :thumb:
Happy new year to all.
Post Mon Dec 26, 2005 10:01 pm
Def get a trolley jack mate, bottle jacks are for commercials and are designed so they sit in a recess on one side of the axle, on a commercial you only need to raise the jack about an inch or so because of where your lifting, but on a car you jack the body, which fully extends the suspension before the wheel is raised so the jack needs its wheels to move along the ground.
Not sure about the one in your ad but a quick-lift usualy has foot operation aswell for speedy lifting winkeye
agent006
Post Mon Dec 26, 2005 10:03 pm
I've got the small 3 ton (i think) clarke trolley jack, and it get up high enough to get wheels off, but only just high enough to get the axle stands under (clark 3 ton). Only cost about Ԛ£30 though, so can't complain. If i was buying again, i'd get a proper full size one.
Globulator
Post Tue Dec 27, 2005 7:06 pm
Get a decent high-lift trolley jack, which goes down when you push the stick forward. Should cost just over Ԛ£100.
Small trolleys are all very well (hey, I've got 2) but a big bugger is amazingly fast and useful.
Chock the wheels well - high lift jacks can tilt your car quite a bit ;)
chu346
Post Tue Dec 27, 2005 7:26 pm
Isn't that CTJ2000G abit heavy? 38.5kgs
DaveD
E30Zone Wiki Specialist
Post Tue Dec 27, 2005 9:54 pm
I bought one from Aldi (2 tonne) which works perfectly and has its own plastic box
DaveD
Post Tue Dec 27, 2005 9:56 pm
sorry it cost me a tenner
