E30 318 1993 Convertible Hazard Lights not working !!
Foggy950
Hello, I have a problem with the hazard lights on my E30 they just stopped working. I have changed the hazard light switch, checked the fuse but no joy. If the switch is pressed in the indicators do not work . If its out they work . The flasher relay seems ok as they flash and it ticks away when i operate the indicators. Any ideas ? Any one had this problem before ?
- **BANNED**
That's a bit odd!
Welcome to the madhouse,BTW.
Main dash earth point is above the glovebox,take the liner out to find it,it's where all the plain brown wires bolt to the car frame.I suspect that this could be your problem.
Youth is wasted on the young.
eko
- Old timer
Golvebox light bulb blown or terminal earthing out?
tom325sport
Have you an alarm fitted to these lights?
