Handbrake issues
listere30
Post Mon Jan 21, 2013 8:08 pm
I recently purchased a 318i, but when i pull the handbrake on(when stationary obviously) the car does not move but the hand brake does not click and stay in place.
Has anyone else had this problem or know what it is and how to fix it?
**BANNED**
Post Mon Jan 21, 2013 8:15 pm
At a wild guess,the lever is bent and is facing the sky!
They fail at the point where the thing changes from being round to being flat,if you can see what I mean....
Best option is a replacement s/h lever.
Youth is wasted on the young.
listere30
Post Mon Jan 21, 2013 8:21 pm
I'm new to the whole e30 world so I have no idea what you mean lol
will it be obvious to see if the cars on a ramp?
is there any other potentials that it may be?
FinalD
Post Mon Jan 21, 2013 8:37 pm
Sounds like the ratchet mechanism is knackered, likely due to the handle being bent (that is what I'm getting from daimlerman's post). Basically it'll be the end of the actual level under the centre console that is at fault, not the brakes or cables.
listere30
Post Mon Jan 21, 2013 8:41 pm
so simply take the centre console out and i will be able to see?
hope it is an easy fix because its a pain not having a hand brake!
**BANNED**
Post Mon Jan 21, 2013 9:01 pm
listere30 wrote:so simply take the centre console out and i will be able to see?
That's right.
The lever should be flat across it's top surface,my guess is that the bit you yank on is bent upwards.
I've tried,and failed,to bend straight and weld,and found that a replacement is the best option.
Martinaston
Post Tue Jan 22, 2013 10:41 pm
Worn brake shoes and then overtightend cable adjusters so its not even reaching the ratchet ?
There is NO nucleus.
dooce
Post Tue Jan 22, 2013 11:48 pm
Was it a prior drift car? I've seen them take the ratchet mechanism out completely so there is nothing holding the handbrake lever up when they are done sliding.
