The rack I've bought has arrived but without the bango/hollow bolts, can I use the bolts off the E30 rack?
According to Real OEM one of the E46 bolts has a check valve, not sure what this is but it doesn't state this on the E30 bolt description.
E46 Steering rack swap - Banjo Bolts
Yes use E30 bolts, that valve only reduces flow to the rack, its of no benefit.PG325 wrote:The rack I've bought has arrived but without the bango/hollow bolts, can I use the bolts off the E30 rack?
