Flywheel and pas fluid
Stonkin
Post Thu Jan 17, 2013 11:48 pm
Hi guys, rather than start 2 threads, thought it best to combine.
With the gearbox going in this w'end, i was considering lightening the flywheel a little after reading up about it. Its a 325 m20. I dont want it rattling on idle so wasnt going to go mad. All the threads talk about weight removal but i couldnt see any references to how much thickness to be removed, which i think my machinist would prefer to know rather than keep removing to weigh.
I will also be putting the pas fluid in. I'm sure i have read not to use normal pas fluid but something else? Its an e46 rack with Dan's kit.
Much appreciated if anyone can help with this
Christian
G-Bear
Post Fri Jan 18, 2013 6:31 am
For pas fluid Dextron 3 I've read on here is the one go for. A new and better quality of oil (replaced Dextron 2) that's less likely to overheat.
As for the flywheel. Magpie on here has sold a few lightened ones recently. Perhaps pm him for info
Stonkin
Post Fri Jan 18, 2013 7:37 am
Dextron 3, that was it cheers mate
Post Fri Jan 18, 2013 7:57 am
5.5kg-6kg is a safe weight .
Post Fri Jan 18, 2013 1:44 pm
Dexron 3 for fluid
5.3kg is even safer winkeye
The weight of the flywheel doesnt cause rattle, that will be your shagged gearbox :wink:
Stonkin
Post Fri Jan 18, 2013 5:53 pm
Cheers guys :)
Silverfang
Post Fri Jan 18, 2013 9:06 pm
Got mine at 6kg, rev's well on the 325i
BMW and Opel, both RWD, both german, both good fun
http://www.clockservicing.co.uk/ For any clock repairs try here.
