Hi
I've got standard 325 sport springs on my car an I would like to put a pair of good shocks in just to get rid of some of the bounce without lowering the car! What shocks do you recommend to use with standard springs will b6's work? Any advice would be great!
Regards Neil
Front suspension
B15NAC
i'm running boge turbo front dampers with the same springs and m50 donk ,the ride is good
+ a yard full of scrap turds
Rtaylor2208
Running Boge's the same as maggpie (GSF £57 a side), -40MM springs and M20 and it rides much better than the shagged out original shocks it was running.
Quaser
I had a set of bilstien b4's and 40mm springs on my m20 touring - nice and comfortable drive
B15NAC
Thanks for the replys! Yea I'm running a m50 in my car on 325 sport springs an I'm happy with the hight just want to stiffen it up a bit!
i'm sure meatballs on here can get the Boge turbo with Discount for you
B15NAC
Ok thanks I will look in to them then! Do b6's only work with lowering springs?
Regards Neil
Regards Neil
