overfueling m20
what would cause this ?
+ a yard full of scrap turds
mark_i
duff blue sensor, leaking injectors, AFM, mis-adjusted TPS...
how would you test an AFM ?
mark_i
involves applying 9volts across one pair of terminals and measuring the voltage change as the flap is slowly opened... i need to check which pins
i need a guide to do this if you can mark ,tia Mick.
blackE30indy
Also FPR mick,make sure the plug under the inlet mani is intact,and that the wires ain't rotten
Common issue this is
i need to check the AFM first then go from there ,soon as i know how to do it
BenHar
I guess you must be a newbie.magpie wrote:i need a guide to do this if you can mark ,tia Mick.
If you look at the top of the page there is a link to the wiki.
You will find it is full of useful information.
There is also a search facility.
Ben
blackE30indy
Ha ha
PRAT!
Search results
You searched for afm test
There is no page titled "afm test".
Mick
Search results
Mick
BenHar
BenHar
Or the third post down when you put "AFM AND test" into the forum search and select "Technical Help" as the forum to search.
You can go to evening classes for old gits on how to use the Internet.
Ben
Ben
Morat
BenHar..stop it please.
BenHar
Both those posts answered Mick's question.Morat wrote:BenHar..stop it please.
Even though he called me a PRAT.
Ben
so you don't have the answer to the question but the Internet does ?BenHar wrote:Or the third post down when you put "AFM AND test" into the forum search and select "Technical Help" as the forum to search.
Ben
I fail to see where your input on this thread is valuable in anyway...
your a c0ck,
Steve
mick
- E30 Zone Meets/Events Team
LOL, ZONE C0CKBenHar wrote:
Hope this helps.
Ben
and very deserved ! i bet he has a jimm'l fix it badge too
BenHar
Do you have the answer? It doesn't seem to be in your post.e30topless wrote:so you don't have the answer to the question but the Internet does ?BenHar wrote:Or the third post down when you put "AFM AND test" into the forum search and select "Technical Help" as the forum to search.
Ben
your a c0ck,
Steve
Ben
BenHar
Why thank you, I'm honoured.Rav335uk wrote:LOL, ZONE C0CKBenHar wrote:
Hope this helps.
Ben
Ben
