Rev counter not working
NickSuzy
Post Tue Jan 15, 2013 2:27 am
Hi All,
I have now installed the M30 into my car and after a few headaches, she is running.
But my revcounter is not working.
I have made the wiring changes as per Lee's post but still nothing.
Am I missing something simple.
Any help is greatly appreciated.
Nick
mcbonio
Post Tue Jan 15, 2013 12:11 pm
Was the donor car a 4pot car?
Bristol_Jer
Post Tue Jan 15, 2013 6:37 pm
Is everything else working as it should?
walinsky
Post Tue Jan 15, 2013 9:08 pm
Do you actually have a revcounter in the first place?
NickSuzy
Post Tue Jan 15, 2013 9:26 pm
The car is a 325e so yes a six pot.
The revcounter did work previously with the M20 in it.
Only just installed the M30 and got it running.
walinsky
Post Tue Jan 15, 2013 9:41 pm
http://www.armchair.mb.ca/~dave/BMW/e30/e30_86.pdf
Check if there's a 4 pin connector in your glove box (C104).
This connector formerly connected to the engine loom, close to the Motronic unit.
It should have 3 wires:
Pin1 - black (SHIELDED!): engine speed
Pin2 - green: power ECU (non fused)
Pin3 - yellow/white: fuel rate
You'll want to use the black and yellow/white ones - and connect them to the engine loom.
I pulled them back - and fed them through the firewall to the fuse-box. From there I connected them to the correct pins on the (chassis side) engine loom connector.
NickSuzy
Post Tue Jan 15, 2013 10:04 pm
I shall have a look tonight, cheers for the advise.
jimbom30cab
Tech 1 freak
Post Tue Jan 15, 2013 10:45 pm
does this make a difference ? - my donor was a 318i
thanks
mcbonio
Post Thu Jan 17, 2013 12:47 pm
Yeah the coding plugs are different on 4 and 6 pot cars IIRC.
Someone chime in and give more accurate details please.!
