Hey guys,
Just after some advice on the best way to remove the map light mirror loom. The wires go up into the actual roof by the looks of it, unlike the wiring for the sunroof and check control panel which can be visibly traced back to the main loom.
cheers
Removing Map Light Mirror Loom
Jim320i
- E30 Zone News / COTM Team
It runs down the passenger side A Pillar and plugs into the loom behind the speaker cover. With some gentle tugging
You should be able to get it to give and come back by pulling the end plugged into the loom. Although I cant remember if its fixed in place down the A Trims... Might be worth moving the cover and just checking under those too
- **BANNED**
As Jim says,the looms run up the n/s pillar behind the trim,held in place by several clips.HJG-E30 wrote:Hey guys,
cheers
I always thought that the overhead check panel wiring was part of the body loom...
HJG-E30
removed the A-pillar trim and the wiring for the sun roof and check control is behind there. Map light mirror wiring however is no where to be seen!
Jim320i
Does it still have the original plug on the end of it? Might have been butchered and wired in elsewhere?
- **BANNED**
Blimey!HJG-E30 wrote:removed the A-pillar trim and the wiring for the sun roof and check control is behind there. Map light mirror wiring however is no where to be seen!
Have removed the panel that holds the sun visors,that should enable you to see where the swine runs.....
Or are you fitting a maplight mirror?
HJG-E30
I'll take some photos tomorrow and upload them. Hopefully some light (no pun intended) will be shed upon the situation as to where the hell my wiring is hiding
Sounds like it may be a home made loom connected to one of the standard interior lights.
