heater blower problem
moggie
the blowers are not blowing,i turn the switch to put them on and nothing happens but it dims the lights slightly on the dash,am i right in thinking the fan has stuck?
G-Bear
Have a floss through here...
http://www.e30zone.net/e30zonewiki/inde ... ter_Blower
You should find your answer. From what I remember the first free option is to take the heater blower fan out and soak it in WD40 get it spinning and lube it up. There's a guide to it in the wiki pages just have to read through..
FinalD
Does it also do this with the engine running and set to max, or does it work on max?
Given that there is dimming of the lights, that would suggest a large draw and the motor could well be stuck. Gaining access to it is simple and is listed in the wiki (here: http://www.e30zone.net/e30zonewiki/inde ... nly_on_Max ), removing the motor is a right pig due to the clip that holds in it place.
G-Bear
As is getting the clip back in around the motor...FinalD wrote:removing the motor is a right pig due to the clip that holds in it place.
FinalD
That's one of tomorrow night's jobs for me, it'll be especially fun as I bent the clip slightly when removing it.G-Bear wrote:As is getting the clip back in around the motor...
G-Bear
There's a small hole on the tab of that clip. I stuck a bradle in it and pushed down on it equally as much as i pushed my tongue into the back of my front teeth.. until either popped... thankfully the clip popped into place first..
macas
Its a peice of piss to change the motor!
It should take 20 mins tops...
moggie
it doesnt work on any setting so i think its the fan that has stuck,sounds like ist going to be fun to get out if it wont go
