Starter motor hot, anyone else had this issue?
s1oww
Post Sun Dec 23, 2012 1:34 am
After the car has been running for about 20/30 min it won't start when I turn it off.
I've checked everything, but I'm sure it's a starter issue with it getting hot.
My friends one has a similar issue too. His will just click when you turn the key, mine slowly turns.
His only does it sometimes, mine does it all the time.
You'd think battery, but its not.
Both cars jump perfect so it's not engine related.
Have any of you had to change the starter motor or heat wrap, or heat sheild?
s1oww
Post Sun Dec 23, 2012 9:10 am
Awesome, thanks I'll try that.
It's straight after and jump as in push it.
As soon as its hot the starter won't turn properly. I tried battery's, jump leads the lot, but not tried re earthing so I'll give that a go.
Driftben
Post Wed Jan 02, 2013 11:57 am
iv had this problem also and still yet to track it down, i thought it was a battery problem or alternator failure but it looks like its down to a earth problem as will said.
at the minute i live with it and just beat its ass when it does it. :twisted:
6pot wilwoods front
4pot Porsche rear
89 E30 stripped running a 6speed V8
Twin Turbo M60 in progress
s1oww
Post Mon Jan 07, 2013 12:44 am
Nope, doesn't look like its the earth :(.
I'm tempted to chuck on a new starter to see if that helps.
At the minute it won't start after its warm.
vokietis
Post Mon Jan 07, 2013 7:54 pm
maybe starter bushes r dry,u need to grease them,had this problem with my 1984 audi quattro years ago...grease helped
FormerMember
Post Fri Jan 11, 2013 12:31 pm
Have you retained the starter heat shield or thrown it away .. ?
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
200272
Post Wed Jan 23, 2013 10:12 pm
I had this issue it was a corroded connection on the Plus junction box/jump point i used off the E34.
