could any one give me any idea what is wrong, (cold start)
Rich320I
Post Fri Jan 04, 2013 9:44 am
right basically its a 325i se standard car.
the problem seems to be confined to just when the engine is cold.
it starts fine first time,
then after a few seconds struggles to rev past 2000ish, and seems to bog down if the accelerator pedal is pressed. if the car is switched of its then very hard to restart and seems to misfire, however when it does restart or if the car is driven up to temp the problem seems to go away completely.
if anyones got some ideas i would really appreciate it? with the weather being cold id rather have some ideas to go on rather than working through everything. thanks in advance
shedrool83
Post Fri Jan 04, 2013 10:07 am
Rich320I
Post Fri Jan 04, 2013 10:18 am
cheers i had taken the precaution of reading that,
i was just thinking if someone had the same symptoms and could narrow it down ie TPS, ICV or perhaps the rubber boot?
cheers for the help though, think may have to get spraying with the carb cleaner :)
shedrool83
Post Fri Jan 04, 2013 10:36 am
Checking for leaks would be my first task also clean out the icv .
Rich320I
Post Fri Jan 04, 2013 10:43 am
cheers il go through the list at the weekend,
reading abit futher into the fueling issue could it be overfuelling and be the blue temp sensor?
cheers for the help once again bud,
**BANNED**
Post Fri Jan 04, 2013 12:30 pm
Do the 'free' checks first,if you have an air leak it could,just,be a case of cleaning a joint and sealing it properly.
Once you are satisfied there,check the reading of the blue sensor,preferably at the ECU plug,with your multimeter and compare your findings to the fiqures in the wiki guide.
Youth is wasted on the young.
