Hid wiring nightmare!
rob_k
Post Wed Jan 02, 2013 9:25 pm
Ive fitted my hid kit as per forum wiki, I've fitted plenty of kits do thought this would be simple. However I fitted the kits and they don't work, I put 12v to them and they were fine. I checked the fuses etc and they seem fine??
I'm thinking it might be worth trying fresh earths??
Any help appreciated
Morat
Post Wed Jan 02, 2013 10:03 pm
Do your standard bulbs still work if you put them back in? (Silly question perhaps but it does eliminate any faults in the car rather than the kit).
eko
Old timer
Post Wed Jan 02, 2013 11:18 pm
This might sound daft but have you plugged the 2 wire Black socket onto the ballast the right way round?
rob_k
Post Thu Jan 03, 2013 7:49 am
I've checked the hid wiring and it's ok and works with a direct feed, I've refitted the original bulbs and now they don't work but each side was working separately before
Morat
Post Thu Jan 03, 2013 9:07 am
Replace the fuses (they can be blown without looking it) and see if it helps. You need your original lamps working before you have another go with the HIDs.
Morat
Post Thu Jan 03, 2013 10:06 am
Oh, and this really should be in tech help.
Abracadabra....
rob_k
Post Thu Jan 03, 2013 11:08 am
Thank you, I'll get back to the drawing board!
rob_k
Post Thu Jan 03, 2013 11:48 am
I've put contact cleaner on all the joints, new fuses and hey presto!! :D thanks for the help
