heater only blowing cold air...
virdi325i
Hi
OK big problem heater only blows cold air, not hot. I have checked all the fuses and they all seem fine.
Any help please would be great ???? the car is a M3
thanks
thanks
are your top and bottom rad hoses getting warm ? is the cooling fan kicking in ? where does the temp gauge sit ?
- E30 Zone Meets/Events Team
It won't have anything to do with the fuses.virdi325i wrote:Hi
thanks
Have you refilled the system recently?
virdi325i
Hi,
Both the Radiator hoses are getting warm, the temp gauge is spot on sitting in the middle.
No i have not recently refilled the system. However i did top it up yesterday to see if it makes any difference, but nothing.
kam-325i
you need to check the hose's (for heat) that go into the cabin thru the firewall, not the radiator hose's.
virdi325i
Hi there
How can i get access to these hoses that are in the cabin
thanks
thanks
kam-325i
you can access them in the engine bay....
virdi325i
ok cool, i'll have a look tomorrow during the day.
thanks
thanks
kam-325i
the heater pipes are on the left side of the brake servo (looking from the front of the car)
harry_p
Sounds like the heater control valve has failed and stuck shut. It's an electronically operated valve which sits on the inlet to the heater matrix.
On your m3 it will be behind the centre console next to the accelerator pedal.
cheers,
harry
harry
virdi325i
Ok cool, I'll also take off the centre console off tomorrow and have a look...
How will i know if its working or not? is there anything i need to look out for?
many thanks
many thanks
Answer the questions and find the problem logically. Don't go following "it might be this", "it might be that" random suggestions, or you'll waste time, money, and possibly end up with new problems that you didn't originally have.kam-325i wrote:you need to check the hose's (for heat) that go into the cabin thru the firewall, not the radiator hose's.
makman
you tried bleeding you coolant system...wak the heater and blower on full..then crack the bleed nipple ..when my m50s thermostat housing seal was drawing air it gathered in the matrix did the air bubble and made her blow cold.
Canny Beat a chromie!'
virdi325i
Morning..... ok i have bleed the system allowing all little bubbles out and still no heat.
next...... I going to take off the centre console and have a look at the heater control valve...
virdi325i
ok .... the pipes coming into the car, bottem one is warm and the top one is cold.
from the engine bay the 2 pipes going through the firewall the top one is cold and the bottem one is warm. ... is this normal?
So what next ?
how do i check the if the heater control valve is the prob?
So what next ?
kam-325i
Brian is your man for this......virdi325i wrote: how do i check the if the heater control valve is the prob?
I know how to check it off the car, but this involves losing all your coolant......
I think the test involves appling 12v to the valve to see if you can hear it "clicking", but dont quote me on that !!!
Andyboy
- Alpina Colada
A cold heater is normally the result of an airlock but it could be other things. Disconnect the cold heater hose at the bulkhead. Anything there? If not, start adding coolant into the rad/expansion tank until it starts to flow. It may be a blocked matrix so it's worth disconnecting both hoses and running a garden hose through one of the heater stubs. The heater valve may be stuck but without 12v they default into the hot setting. Try these first though.
If the heater valve is knackered, you can remove it and drill a 5/6mm hole down into the short stub where it bolts to the matrix. This bypasses the valve so you at least have heat whilst you get a new valve.
virdi325i
hi there,
cold heater hose at the bulkhead - is this the one on top?
'disconnecting both hoses and running a garden hose through one of the heater stubs'
- doing this will i have to drain the system (raditor)
is it running a garden hose through the pipes removed or plug the hose from where the pipes have been removed (in to heater valve)
sorry just wana makesure, don't want to screw it up even more.
thanks in advance
thanks in advance
Andyboy
- Alpina Colada
virdi325i wrote:hi there,
- It 's the one that's cold.......
- No.
is it running a garden hose through the pipes removed or plug the hose from where the pipes have been removed (in to heater valve.
- Both hoses off.
thanks in advance
If you connect a garden hose to the heater stub pipes, it MUST be connected to the bottom stub, or the valve is likely to be damaged, even if it isn't already.
harry_p
Very unlikely to be an airlock. M3s self bleed, and I've never heard of anyone getting an airlock in one.
The one hot and one cold pipe to the heater is a clear indication there's no flow, the input will get warm through heat transfer and turbulence in the water system.
Imho if the rest of the cooling system is in decent condition then it's very unlikely the matrix will suddenly clog, I'd put money on it being the control valve at fault.
I had one go randomly on my e36, but it failed open so was constantly hot, others have had them fail shut.
cheers,
harry
harry
