Fuel tank
bar2
Post Sat Dec 29, 2012 10:27 pm
Hi I need to fit a new tank to my 318i convertible can anyone tell me how long the job should take I will be doing it in my garage at home
shedrool83
Post Sat Dec 29, 2012 10:32 pm
Just done this last week.
Took me about 1.5 hours i think getting a hand off the cousin.
Post Sat Dec 29, 2012 10:40 pm
If you have never done it before then start early and you might be done by evening if your lucky and have some good mechanical understanding
Post Sat Dec 29, 2012 10:44 pm
tip of the day .
don't put your axle stands on the rear beam .
shedrool83
Post Sat Dec 29, 2012 10:48 pm
As Dan says above give yourself plenty time if you havent done one before.
Plus it helpful to mark which pipe goes where when you remove them.
magpie wrote:tip of the day .
EVER!
**BANNED**
Post Sun Dec 30, 2012 9:51 am
Allow at least half a day.
Youth is wasted on the young.
Post Sun Dec 30, 2012 9:53 am
daimlerman wrote:Allow at least half a day.
Per rusty bolt.
**BANNED**
Post Sun Dec 30, 2012 10:13 am
Per rusty bolt.
I have now swapped three E30 tanks,and only found one 'playful' bolt.Natually it was one of those two very close to the rear beam!
Post Sun Dec 30, 2012 10:15 am
If the back end of the car hasnt been taken apart for a while ( if ever ) forget doing it in a day
This will almost certainly turn into one of those jobs where you will notice other parts that are past their best and you will find youself making a list of "whilst its in bits we may as well replace....." parts.
Good luck.
**BANNED**
Post Sun Dec 30, 2012 11:23 am
capri_rob wrote:If the back end of the car hasnt been taken apart for a while ( if ever ) forget doing it in a day
Good luck.
With that in mind,what are the OP's rear brake pipes like? winkeye
Funnybear
Post Mon Dec 31, 2012 12:16 pm
You'll be dropping the rear beam . . . . Get them rubbers done!
Post Mon Dec 31, 2012 1:17 pm
Funnybear wrote:You'll be dropping the rear beam . . . . Get them rubbers done!
It's a good time to do all the twenty year servicing under the back end at the same time, but there's no need to drop the beam for a tank change.
