Interior Light Upgrade Bulbs
jon-m42
Post Fri Dec 28, 2012 10:24 pm
Hi Guys,
Recently having upgraded my headlights to HID's. I must say its probably by far the best £20.00 upgrade i have done tot he old girl.
Switching the interior lights on seem a tad dim. I have the standard yellow light bulb installed from factory and they seem very dim even though if the car is switched on or off.
Has anybody here completed a change to these lights?
any upgrade bulbs that you all can recommend or is this something that nobody yet has done?
regards
Jon
Post Fri Dec 28, 2012 10:26 pm
Go LED bulbs, straight swap and much better light output :D
jon-m42
Post Fri Dec 28, 2012 10:30 pm
which LED bulbs ?
what colors do they come in ?
finally where do i get them from and how much do they cost?
TPS
Never bought LED, where do you get them from? Halfrauds?
jimbom30cab
Tech 1 freak
Post Fri Dec 28, 2012 10:35 pm
TPS
Post Fri Dec 28, 2012 10:38 pm
Thanks Jim
jon-m42
Post Fri Dec 28, 2012 10:43 pm
oh gosh not a deep blue color
trying to stay away from the deep blue color as to many chavs around the area have them as their headlights and also their interior lights are all blue.
anything ice white maybe ???
Post Fri Dec 28, 2012 10:44 pm
The white one would probably be better, if you want brightness:
http://www.ebay.co.uk/itm/1x-White-Inte ... 564e99c925
Post Fri Dec 28, 2012 10:50 pm
Go for White only. :D
zaust
Zone day release
Post Fri Dec 28, 2012 10:59 pm
On my breeding tank I used led festoons as the BMW light unit was an easy fit to the lid. Excellent white light and lasted a year of all day use and in damp conditions just like the inside of an e30.
Go for it.
M30 Tech 1 Touring on gas.
TPS
Post Fri Dec 28, 2012 11:04 pm
Sold, I've just ordered a couple. Anyone know if the Touring Tailgate light & the Maplight Mirror can be upgraded?
jon-m42
Post Fri Dec 28, 2012 11:07 pm
TPS which ones did you go for ?
any of the following :
or
Post Fri Dec 28, 2012 11:08 pm
I would put them into the rear numberplate lights too.
TPS
Post Fri Dec 28, 2012 11:12 pm
jon-m42
Post Fri Dec 28, 2012 11:25 pm
cheers buddy
Post Fri Dec 28, 2012 11:28 pm
I just ordered one too, as the interior light on my car is a bit on the feeble side.
Being LEDs, I'm guessing that they have to be installed the correct way round though...
Post Fri Dec 28, 2012 11:31 pm
i'll join the band wagon on the super white ones ,could do with map light ones if any links to them ?
Post Fri Dec 28, 2012 11:33 pm
magpie wrote:i'll join the band wagon on the super white ones ,could do with map light ones if any links to them ?
Maplight ones are not availabe Mick, but I know a guy who I buy all my lights off was ooking into getting the right ones made.Be carefull if anyone on the bay says they will fit, they won't.!
jon-m42
Post Fri Dec 28, 2012 11:38 pm
join in with the lights guys ive just ordered a few ...
better interior light means i still have to pull out my glasses but this time i hopefully wouldnt need to on the light on the back of my iphone 4s
Post Fri Dec 28, 2012 11:52 pm
if anything comes of it do let me know Rav :)
Post Sat Dec 29, 2012 7:37 am
Maybe on the cheap cheap ones, but most have the correct resistance built in not to.
Post Sat Dec 29, 2012 10:21 am
Rav335uk wrote:Maybe on the cheap cheap ones, but most have the correct resistance built in not to.
Not an ideal design, packaging a high dissipation resistor near LEDs!
baggimodo
Post Sat Dec 29, 2012 1:35 pm
How many to do the rear number plate? I would go and check but its pi$$ing it down! :P
baggimodo
Post Sat Dec 29, 2012 1:40 pm
Cheers bud :)
jon-m42
Post Sat Dec 29, 2012 7:15 pm
Just awaiting on delivery now.. expected date 4 jan 13 :(
now finally guys the only yellow dim lights on my car now would be the parking lights small w5w bulb.... are there any upgrades on these i did a google search but did not find much.
anybody replaced these too? if so which ones did you get and where form ?
all help again is very much appreciated.
cheers guys
jon
G-Bear
Post Sat Dec 29, 2012 9:39 pm
This is a great little upgrade to cheer me up, whilst I save cash for the more expensive parts I need for the car...
Also jon-m42 after reading your post on Hids.. I'm going to put an order in for those too :D :D
318isPMK
Post Sat Dec 29, 2012 9:45 pm
How many would I need to swap them all over.... 4
Post Sat Dec 29, 2012 9:46 pm
jon-m42 wrote:Just awaiting on delivery now.. expected date 4 jan 13 :(
cheers guys
jon
if you buy ice white headlight bulbs you'll get the side light bulbs free in most cases,some are chav blue though i found with one order.
you can get them for the fogs and i'm running the 100w high beams :twisted:
G-Bear
Post Sat Dec 29, 2012 9:52 pm
And ordered, AceParts are doing well on ebay tonight..
jon-m42
Post Sat Dec 29, 2012 10:04 pm
cheers guys
g-bear thanks
after driving a friends e46 i was quite blow away by the amount of night visibility it had to offer. i presume he has the standard factory bmw HID kit however after a bit of research and help from the zoners i was on my way to see the same light behind my old turd.
as for the interior lighting i just thought why not something little that will look good i geuss...
i never really use my fog lights much as motorway driving is not in my daily commute anymore.
so all i really need to know now is which parking lights shall i or we all here invest into?
i understand they are just to tiny little bulbs but is there is anything far from the chavy blue/purple and the old yellow color and something ice white would do me just fine.
glad you all are benefiting from my post why not, if it improves the lighting which gives it a modern contemporary look hell yeahh :cool:
harry_p
Post Sat Dec 29, 2012 10:07 pm
You can get white led sidelight bulbs too.
Unfortunately a lot of them are quite blue looking, I've yet to find by that are a nice crisp hid matching white.
There must be some which match, but there are so many out there it's hard to know where to start.
cheers,
harry
Post Sat Dec 29, 2012 10:08 pm
Post Sat Dec 29, 2012 10:10 pm
harry_p wrote:You can get white led sidelight bulbs too.
i do have some but had to test fit a few samples before i found the required look .
