Aircon idle speed not working
Definately (was) a 325e in the beginning, but the engine has seen the Alpina mods, so a big difference in performance. Sorry about the bum steer.
The ecu is the original one the car was born with, so let me know what to check and I will have a look.
Steve
Steve
Lots of mods. 325i Head, ported and polished, 325i cam, pistons, blah, blah, blah.
Intake manifold is the 325i, but still has the 7th injector for cold start and the idle control is original.
The ECU has been chipped on a rolling road, so not sure exactly what it is. I cannot see any box sitting on top of the ECU, just the alarm/immobiliser.
Steve
Steve
e301988325i
Thinking aloud, are you just trying to trigger the higher idle, or, are you turning the aircon on and the idle is not raising? i.e. could the load of the aircon compressor be dragging the supposedly raised idle down to the original level?
I said:
e30topless said:
lock the wife in there
Hi Will,
A great combination, 325i running gear and the 327 stroke. Beautiful tourque curve that allows you to pull away in 5th from 1200rmp if you choose to do so.
I have 3 BM's including a e36 coupe (red of course) and a e46 330ci CAB, but my favourite by far is the E30.
Yes, already attended to the TPS setting as the car had been mothballed for a few years and was definately not running well at first, but after replacing the TPS and adjusting as per the wiki it idles perfectly unless the aircon is switched on.
The aircon had been out of action for probably the last 8 to 10 years, but I do remember it did idle up when the AC was switched on.
The ICV is the 2 pin type. I think the later 325i has a 3 pin type, so not the one in mine.
I have a full workshop manual (with my son at the moment) so will not be too difficult to find out where the ICV goes to in the ECU, if that's where it ends up.
I will post again when I get my manual back!!!
Steve
Steve
e301988325i
Realistically you need to get the belt off and check the pump turns smoothly by hand before fussing over the elecrics. HTHjermyns wrote:The aircon had been out of action for probably the last 8 to 10 years
I said:
HTH,
Aircon works fine, new compressor, receiver/dryer and gas....loads of cold air coming out, but loads up the engine because the idle-up is not being triggered.
I own a auto mechanical business, so will be simple to fix when I know what to look for, hence the questions to Will and Brian who have the deserved reputations of knowing this stuff inside out.
Happy to have input because that how we all learn
Steve
Steve
- Brianmoooore
Is the idle speed control working at all? Or has it been set up on the throttle stop, like an older/more primitive car with no feedback loop?
Does the idle hold steady if you turn every electrical load on?
Does it hold speed if you drive along in second gear with your foot of of the throttle and come to a slight incline?
Brian, yes the ICV is set up to work and will maintain idle speed when all electricals are turned on. Haven't tried the 2nd gear test but I will.
Will. OK, looks like I have to do the testing the hard way but it will not be very soon.
We are 2 hours south of Sydney and it continually amazes me how many people will leave to go on holidays without either servicing their car, or worse leaving with a known problem only to break down around my location
Flat out at the moment, so no working on my toys
Steve
Steve
