flywheel rattle.. bad bearing.. eh?
- E30 Zone Meets/Events Team
- Contact:
Yep.
Dual mass plate isn't springloaded, where s the singlemass frictionplate is.
Oh, and it's alot dearer too.
Got a part number Rav? Can't find one anywhere...
Also if i'm gonna take the box off I might as well change a few parts too....
Flywheel & new bolts
Clutch friction plate
Throwout bearing
Prop shaft guibo
Anything else I might as do whilst its off?
Throwout bearing
Prop shaft guibo
leeparkes
Spigot bearing that goes in the end of the crank.mcbonio wrote: Flywheel & new bolts
Throwout bearing
Prop shaft guibo
Bristol_Jer
its the layshaft in the gearbox (gearbox rattle) nothing to worry about. i know many E30's with the mods that do the same
Layshaft noise usually disappears when you press the clutch, this noise doesn'tmcbonio wrote: It still does it when you shut the engine off with the clutch pressed in which makes me think its not the gearbox and more the flywheel/bearing.
My m30 and box have no mods, its an m30b35 with a getrag 260/5 box from the engine.
Its deffo the flywheel, it rattles on shut down with clutch in or out. With engine running and parked on an incline it knocks too so can't be the gearbox as thats totally disengaged.
I shut the car off whilst in motion today in 4th gear, the engine shut down smoothly with no rattle, which confirmed my suspicion of the flywheel not rattling when its loaded up with the clutch and gearbox.
So parts.!.;
Throwout bearing
Prop shaft guibo
Spigot bearing
Anything else?
So parts.!.;
Throwout bearing
Prop shaft guibo
Spigot bearing
Anything else?
jimbom30cab
- Tech 1 freak
i know its speaking the obvious but new GB oil?
selector shaft seal maybe? part 16 here: http://www.realoem.com/bmw/showparts.do ... g=23&fg=15
i have a decent M30 guibo if you want it as i'm fitting a 325i prop therefore only need a 325i guibo
Yeah I put fresh ATF in it about a month ago when I did all the shifter bushes. Shifts beautifully.! The car has no running issues at all.! Flywheel still rattles.!
I might just drop the gearbox and remove flywheel and run the engine to make sure before I splash out on a 250 quid flywheel.... I'm assuming its ok to run the engine with no flywheel?
jimbom30cab
- Tech 1 freak
i'd defo split them first have have a good inspection in there, you might not need to run the engine. If you do i'd do it for a very short time as the crank maybe suffer harmonic vibrations which could cause undue bearing wear, personally i'd think hard before taking that risk.
i bet its something simple, loose bolt or maybe the little dowel - part 7 here come loose
http://www.realoem.com/bmw/showparts.do ... g=11&fg=20
I don't think it's anything small and loose inside, the rattle is much heavier than that, it can be heard and felt inside the car.
I personally think the bearing or DMF is bad and allows loads of play in the 2 halves. When the crank comes to a stop the extra play allows the other half of the DMF to jolt back and forth.
Look at this video,
Or this,
Once those DMF springs between the 2 halves go which absorb the shock from the engine to clutch the DMF just rattles like a tin can.
Look at this video,
Or this,
jimbom30cab
- Tech 1 freak
i see, well in that case it should be easy to ID when you have the gear box removed
i'd get over to the BMW 5 forum and look for a e28 M535i flywheel.
more expense though
more expense though
jimbom30cab
- Tech 1 freak
clutch friction plate one with springs on
i have one here, do you want me to look for a part no on it or post a pic of it?
probably do it tomorrow if you do as off to bed soon
how old is the flywheel??mcbonio wrote:My m30 and box have no mods, its an m30b35 with a getrag 260/5 box from the engine.
So parts.!.;
Throwout bearing
Prop shaft guibo
Spigot bearing
Anything else?
- Contact:
Nearly right.
The E28 singlemass flywheel needs an E28m535i clutch kit.
It's the custom jobbie I have that needs the other clutch which is elusive atm
jimbom30cab
- Tech 1 freak
Rav, i have this clutch plate, cover plate and flywheel but was rather hoping to re-use my M30e34 535i release bearing and it's in good nick and all fits nicely....do you think this would work ok?E28m535i clutch kit
jimbom30cab
- Tech 1 freak
bought mine from a chap on the bmw5 forum who bought it and changed his mind..Try the usual places, ECP etc, maybe even ebay ??Where can you get the e28 m535i clutch kit from and how much
leeparkes
Dunno if any of these numbers help.
Thats a Sachs E28 3.5 friction plate.
My flywheel is E28 525i, the lightest out the lot at 7.5KG, 3.5's are 10KG.
You can use ANY E28 M30 flywheel and ANY E28 M30 240mm friction plate but the pressure plate must be from a 3.5 to handle the power.
- Contact:
Not sure on the size difference, if any, of the release bearing, but don't see why not.jimboe39540i wrote:Rav, i have this clutch plate, cover plate and flywheel but was rather hoping to re-use my M30e34 535i release bearing and it's in good nick and all fits nicely....do you think this would work ok?E28m535i clutch kit
ECP, and it's the dearer of the M30 clutches.mcbonio wrote:Where can you get the e28 m535i clutch kit from and how much?
