E36 rack work for m42 318is?
Gruelius
Sat Aug 25, 2012 3:41 am
I have been told it dont clear the headers... anyone tried this?
DHFiS
Sun Aug 26, 2012 6:55 pm
I've done it and it works but there isnt much clearance. When I first did it the UJ was touchng the manifold but you can jig it about with spacers to get it free. Cant remember exactly what I did.
WEEMANDANBRITTON
Sat Dec 08, 2012 8:56 am
hi,
i have done it two days ago, me and a fellow zoner (driftnethin) spent 5 hours making a custom uj and making up pipes to get it to fit but its on an and its lovely!! just waiting for a z3 rack to show up now!!!
Dave_M3
Wed Dec 19, 2012 12:18 am
there's no need to make a custom uj for an M42, lol.
Front holes, E28 M5 engine mounts... job done :)
joeseth
Thu Dec 20, 2012 8:53 am
Sweet I've already got the m5 engine mounts and a z3 rack sitting at home so should be easy haha. Do I just use the e30 u-joint I can't remember? I'm sure it will all make sense once I get it apart. Want it done in a day though as is my only car.
'89 Lachsilver m42 coupe - Sold
'92 Laguna Green Convertible M50
'97 e36 328i sport - Daily
'89 Alfa Romeo Sprint cloverleaf
joeseth
Thu Dec 20, 2012 8:59 am
Oh of interest how much are your pipes and spacers dave?
Rallyprep_UK
formerly Driftnething
Fri Dec 28, 2012 9:15 pm
WEEMANDANBRITTON wrote:hi,
Wemandanbritton and I used one of these on his 318is...
http://www.ebay.co.uk/itm/Bmw-E30-E36-S ... RK:MESE:IT
And the original E36 pipes just needed a tweek on the end going to the rack and the low pressure side needed cutting and joining with a small piece of pipe/fasteners.
Clearance to the exhaust manifold was tight but it works on the original mounts etc in the forward rack mount holes.
For a good job I would use the linkage and m5 mounts (I like the feel without the rubber steering damper).
Will
Racing is living, everything else is just waiting...
http://www.rallyprep.co.uk
Rallyprep_UK
Fri Dec 28, 2012 9:16 pm
for spacers we just cut down some metal tube...
12mm if I remember correctly ?
AndyTB
Thu Feb 28, 2013 2:53 pm
E36 rack on my 318iS - Previous owner had it done, but my god it makes a difference from other E30s i had driven. Sadly can't comment on how easy it is to do..
Kedge
Thu Feb 28, 2013 3:34 pm
I had one on mine mounted on the manual rack holes, standard UJ, standard mounts and never had any clearance problems.
For spacers I've always used head bolt washers. :D
Instagram - Kedge85
