Chip out of an e34 dash panel maybe?
Rev counter for a v8 e30
tomislav
Anyone know what the best way is to get the rev counter on a v8 converted e30 working properly? At the moment its apparantly reving to about 9500rpm
Wouldn't a 4-pot coding plug work? Maybe with a simple divider circuit (to divide by 2) in the connection between the engine and the clocks.
HairyScreech
whats the feed for the e30 clocks? does it just come off the negative side of the coil or out of the ecu?
(can't remember without looking it up)
I think on most E30s, it normally comes direct from the ECU, however, he has a V8 fitted, so it will depend on which engine management system he has in place.
HairyScreech
True, just wondering if you could use the diode trick and pick up of the negative side of 4 of the coils and feed that back to the ecu. Quick and dirty but it works and it works well.
tomislav
I bought the car with the engine already fitted but it looks to be a bit of a lash job, as far as i know its ecu fed
And which engine and management ECU are fitted?
penton08
This works!!Speedtouch wrote:Wouldn't a 4-pot coding plug work? Maybe with a simple divider circuit (to divide by 2) in the connection between the engine and the clocks.
tomislav
M60B40, god knows on the ecu, but i can find out
And what was the car originally, or what coding plug does it have in the instruments cluster - four or six-pot?
tomislav
6 pot. Looks like i need a 4 pot chip with a signal halver thing then.
jmc330i
Dakota Digital is a name that I remember from a few years back. It's an American thing, but there was a couple UK stockists at the time.
It was used to convert the signal from an 8 cyl to run a 4 cyl rev counter.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
tomislav
Dont have the panel from the doner car mate, i didnt do the conversion, its long gone
