sun roof leaking
gaszman
Post Thu Dec 27, 2012 9:10 am
after all the fookin rain and leaving the car on the drive when pulling away water dripping from the cnte of the roof seam at the rear seam , then when stopping water dripping from seam passenger side on the seat any ideas is there a rubber in need of replacement
its a chrome tech 1 87
Das_BMW_E30
Post Thu Dec 27, 2012 9:22 am
The sunroof rubber only prevents lots of water ingress, it is not a waterproof seal.
Water will get past it, caught in the tray, and hopefully flow out the run off tubes located in each corner of the tray.
Trays rot, corner tubes get blocked or crack an leak, it will need looking at ASAP...
**BANNED**
Post Thu Dec 27, 2012 12:05 pm
Sunroof tray has a drain in each corner,visible when the sunroof is opened fully.
You need to thread a bit of stiff wire down each drain to ensure that they are clear.
Youth is wasted on the young.
BenHar
Post Thu Dec 27, 2012 12:46 pm
daimlerman wrote:Sunroof tray has a drain in each corner,visible when the sunroof is opened fully.
Plastic strimmer cord is good for this.
Ben
steve_k
Post Thu Dec 27, 2012 1:09 pm
Ben
also a straightened (sp?) out metal coat hanger does the job & is a bit stringer for trying to clear any blockage.
BenHar
Post Thu Dec 27, 2012 1:10 pm
But is more likely to poke though the side of the rubber pipes.
Ben
Post Thu Dec 27, 2012 1:21 pm
We need pictures of the holes / rust/ nastiness, research innit ! :)
steve_k
Post Thu Dec 27, 2012 1:24 pm
BenHar wrote:
steve_k wrote:
BenHar wrote: Plastic strimmer cord is good for this.
Ben
true didn't think of that :o:
**BANNED**
Post Thu Dec 27, 2012 1:29 pm
pacerpete wrote:We need pictures of the holes / rust/ nastiness, research innit ! :)
Pete
Drop your trousers and shreadies and crouch over a mirror..... :mad:
steve_k
Post Thu Dec 27, 2012 2:01 pm
Pete
oh please dear god no!!!!!!!!!!!!!!!!!!!!!!! :eek: :eek: :eek: :eek: :eek:
mind you i think gert_8 & diable might like it winkeye
**BANNED**
Post Thu Dec 27, 2012 2:12 pm
steve_k wrote:
Pete
Please note;
I did not request a photo! :D
Post Thu Dec 27, 2012 3:23 pm
Have you got the pics yet Malc ? :)
**BANNED**
Post Fri Dec 28, 2012 12:35 am
pacerpete wrote:Have you got the pics yet Malc ? :)
I spat wine all over the moniter,worse than Kos,you are!
