Spent what seemed like an agonising hour cranking the engine over with no plugs in to build the oil pressure, which eventually registered and got up to a fairly healthy 20psi before I stopped.
Got the coolant system all nice and full.
Checked for any leaks, couple of drips but only from low pressure connections so I'm not too concerned.
Click the fuel pump relay to prime the fuel system.
Get the laptop outside and plug the Emerald in.
Run the Emerald software with the ECU plugged in to the car and the PC.
Turn the key, the light turns red, the ECU primes the fuel system for a couple of seconds...............
And then..............
The PC says there's no connection to the ECU so I can't do shit
It's been ten long months of skinned knuckles and late nights working towards this day and now I've been let down by something that completely baffles me: The computer!
Ho well, any suggestions guys?
Cheers!
