M50, been there, whats next?
Sjoerd320i
Post Mon Nov 05, 2012 9:33 am
Hi lads,
I had an M50 fitted to my last car, a more door 320ia. It was a good engine wich made about 200 bhp.
Now that I have the convetible I want to do another swap. I don't want to do another m50 as this car is heavier than the 4 door so it won't be as fast.
M52 is an option but they are getting a bit common so I have been thinking about something else a little les common but I have no idea what to go for.
I don't want a v8 so that's out of the question. And m-power engines are just to expensive atm.
So maybe an m54 3.0? Or is the m52 2.8 such a big improvement on the m50 that I should just stick with that?
My m50 did 0-62 in about 6.5 seconds, did about 155 mph and I want it to be faster than that.
maf260
Post Mon Nov 05, 2012 10:03 am
M50 turbo?
I doubt that a M52 will make a massive difference tbh
TSM3
Post Tue Nov 27, 2012 1:07 pm
An M52 in a convertible won't be that much quicker that what you had.
I have an M52 in a poverty spec coupe and it hits 60 in about 5.6 seconds. Factor in a heavier convertible and you're probably around the 6 seconds mark.
Post Tue Nov 27, 2012 1:15 pm
If you want to build something then an M52B30 isnt a lot of work if you dont mind spending the money. Your looking at approx 240hp and 240lbft with standard engine parts and management in an alloy block. Beats an M54 hands down :D
jed-bimmer-williams
Post Mon Dec 10, 2012 9:33 pm
M70 5.0? Dont see that often...
jed-bimmer-williams
Post Mon Dec 10, 2012 9:34 pm
Post Mon Dec 10, 2012 10:11 pm
jed-bimmer-williams wrote:M70 5.0? Dont see that often...
For a good reason
jed-bimmer-williams
Post Tue Dec 11, 2012 12:03 am
Lol yeah... End result is a nice thought though!
I am starting a project soon and think I've decided on a Jap turbo engine for a coupe...
Sjoerd320i
Post Sat Dec 22, 2012 11:10 am
I'm not really looking for a "hybrid" engine build, just a straigt forward swap.
It will probably be an m52 as that will give me a little bit more power than the old m50 but wont cost me as much as an s50...
Lol v12 is not an option.
ross_jsy
Post Mon Dec 24, 2012 10:40 am
All a bit wasted in a convertible. Ideally you want something just to cruise around in with lots of low down grunt like an m30
Post Mon Dec 24, 2012 8:52 pm
ross_jsy wrote:All a bit wasted in a convertible. Ideally you want something just to cruise around in with lots of low down grunt like an m60
*Cough* :D
Sjoerd320i
Post Thu Dec 27, 2012 10:02 am
True, if I were to put a heavyweight in it might as well be an m60 :D
I really want to have a 6pot and more than 12 valves.
Also 24v's are better on fuel than an m30 anchor...
Post Thu Dec 27, 2012 10:57 am
M52B28 then, cheap and readily available
