Need help identifying petrol tank hoses
RoadHazard
Post Mon Dec 24, 2012 6:44 am
I'm swapping my 55L petrol tank to 63L and need help identifying these hoses please. Can I reuse the existing hoses on the 55L tank? I have both internal and external pumps.
These. From the RH fuel pump area.
And these. From the LH corner.
Another angle
Thank you.
Grrrmachine
E30 Zone Wiki / Team Member
Post Mon Dec 24, 2012 10:15 am
1 is the breather hose to the fume tank in the wheel arch
2 is the return hose from the wheel arch tank
3 and 4 are the same hose, which IIRC goes to the carbon cannister in the passenger side of the engine bay
5 is the fuel supply line from the pump into the fuel filter
6 is the return feed from the fuel rail
