what diff do i need
manse73
Post Fri Dec 21, 2012 5:01 pm
the car is running a 1800 diff and has had a 2.5 conversion done what would the best diff be and who would have one at sensible pennies help please
the car is j reg
Sebring grey motorsport convertible
Post Fri Dec 21, 2012 7:49 pm
You don't say what model, but you need a 3.64 (my choice), 3.73, or (boy racer choice) a 3.91.
These are all likely to come fitted in the larger 188 medium case diff., but will fit in place of your small case version with a small adjustment in prop. length, as long as the diff comes complete with output flanges.
manse73
Post Sat Dec 22, 2012 1:57 pm
The car is a j reg cabbie that started life as a 318. Would it be best to get a prop rather than adjust the length
ross2009
Post Sat Dec 22, 2012 7:40 pm
kev on the props they have a slide adjuster on the middle of them you undo the big nut in the middle slide the rear secion of the prop out to the output flange of the diff then do the nut bk up its like a pinch sleeve the nut clamps the prop
Turbo M20
v8 project 6.0 twin turbo
