Depending on where you put the adjustment handle, you can hear the ratchets slipping as the seat moves back and forth, but it won't lock in place. I've done the two things in the Wiki (lots of WD40, and tightening the rear screws) and all they did was remove the ratchet sound.
The rear screws were pretty tight already, so I doubt anything's broken - more likely something's seized in the -15 degrees we have here, but I have no idea what
