I`m in the process of buying some 16" rims which have an et of 20 as i understand it bbs have an et25.
i dont really understand what it all means except it means off set,what i`m asking is do i need to fit 5mm spacers?
Tia
Wheel spacers
age
- Formerly twist316
depends on the width mate.
what j are they
what j are they
age
- Formerly twist316
5mm spacer and they'll be perfect
harry_p
no.
et 20 means they will already stick out 5mm further than an et25 wheel (of the same width.
putting a 5mm spacer will make the new wheels et15, so theyll stick out 10mm further than the standard wheels.
cheers,
harry
harry
age
- Formerly twist316
my bad!
harry is correct, should have read more carefully!
