Replacing the M20 320i fan.
CircuitRacer
Post Mon Dec 17, 2012 7:45 pm
Hi, my viscus fan is missing a blade. Ive sourced a 2nd hand job which Im hoping to fit without removing the rad. A mate of mine reckons a 32mm spanner on the fan nut and turned to the right should remove it but the belts etc move with the fan pulley. How do I lock it up and do you reckon the rad has to come out to swap em?
Quaser
Post Mon Dec 17, 2012 7:57 pm
You will need to use the shock method
Put the spanner on the nut and hit it clockwise with a hammer
You might have to do it a couple of times but it never fails for me :)
If its just the fan you want to remove - then its 4 bolts using an allen key - just take of the fan shroud and you should be able to access them. Rad can stay in.
maxfield
Post Mon Dec 17, 2012 8:00 pm
I usually use a hammer and a screwdriver to shock it off.
rix313
Post Tue Dec 18, 2012 12:36 pm
Can't you access the 4 bolts holding the fan on from the front and just change the fan rather than undoing the viscous clutch?
Demlotcrew
Post Tue Dec 18, 2012 3:13 pm
Should be in Tech Help.
CircuitRacer
Post Sat Dec 22, 2012 2:29 am
Cheers to all for the replies! Will give it a couple of whacks this weekend, anybody have an LSD FOR SALE?
Andyboy
Alpina Colada
Post Sat Dec 22, 2012 12:17 pm
maxfield wrote:I usually use a hammer and a screwdriver to shock it off.
I have a proper chunky 32mm spanner, cost me a tenner a few years ago.
Nothing worse than seeing molested 32mm viscous nuts*.
*I've left myself wide open there. winkeye
TPS
Post Sat Dec 22, 2012 12:20 pm
lol :D
Wait for Pete to read it!
Post Sat Dec 22, 2012 1:05 pm
Re the 'gape' You might want to replace the Grolsch bottle :)
Andyboy
Alpina Colada
Post Sat Dec 22, 2012 2:07 pm
It was Heineken - follow the Bear!
