Nearly a year since my last update, haven't done much in the way of bodywork, bar the last section off arch i sealed up. Have mainly bee accumulating parts, upgrading parts
and procrastinating before more sand blasting.
I hope to do one last push and finish the underneath this year, at least getting it sealed up with epoxy before the winter
anyway last fab work it did on the car
i've also prepped the brakes for fitting - big red seal kit, hel stainless nipples and good ridge hoses
Did some throttle body work, the idle valve has been bunged up as you can't weld it. I made a part on the lathe out off aluminium and also modded a bolt to block the other one - both flushed off internally. Also in the picture is the ali temperature sensor mount for the audi AIT sensor.
As I'm working around the rear i finally got the beam and camber tabs installed (should have been in feburary) I've now begun working at an engineering firm so made made myself some stainless versions - TIG'd on and ready for a heavy bead blasting. The ends have rusted badly as i burnt out the beam bushes last time as i was sick of them.
Other progress has been a new hose cover for the rear arches, i found some offcuts of carbon mat in the workshop so had a go out making a replacement. It turned out OK the biggest mistake i made was getting the slow cure resin and it taking an age to go tacky, i did wait but not long enough. This meant it would hold and adhere to the tight curves and leave that nice gelcoat finish. But you can't see the inside and once painted will be fine. I was surprised at how well it drilled it thought it would be a major ball ache but glided right through.
Also bought a torsen - i flushed the inside out with paraffin and topped up with new oil, new zinc bolts, new gasket and made a nice stainless bracket to hold the speed sensor. I blasted the aluminium rear section and the outputs but not the body as i was worried about the seals - i don't hold out much hope for it staying rust free but it looks good for now
Now i can TIG weld I've decided to remake my down pipe and incorporate an external waste gate and some flexi's. The worry off overboost is the main reason and my old design wouldn't really flow that well from the wastegate also it now looks sh!t to my eyes - all round it should be better and faster!
Also going to re-do the charge pipes in aluminum at some point
Major work is need to the rear and for those of you who can visualise the rear end all the cross braces are heavily rusted and going to come out - can anyone think of any negatives off replacing the sections that brace between the chassis rails being replaced with 2-3mm channel? both the arb mounting one - and the section the seat belt braces bridges too obviously this will stiffen it up but will it change the handling in a negative way?
